Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
VOLUME PICTURE IS FINE, CHANNELS ARE FINE, BUT THE VOLUME DOES NOT WORK. PROBLEM MAY BE DUE TO STORM FROM THE OTHER NIGHT.I TRIED UNPLUGGING THE TV, BUT THAT DID NOT WORK.
    Genius:
  • 1,153 Answers
Check first to see if n menu speaker are off or then you may have to change audio amp IC. in 7700 location before changing look for blown round black fuse 2A 250V, 1700's
Posted on Sep 05, 2007
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
Vizio xvt553sv no picture and will shut off
Good evening
Since unplugging will not work, take the remote click on SETUP and go through general as well as picture. See if you cannot make it better.
Good luck
kolbrun
Jul 10, 2012 | Vizio XVT553SV 55 in. LCD TV
Can't get channel manager to come up. Can't change channels. Electric went out from a thunder storm. Transformer hit by lighting. Now can't get channel manager to come up and can't cha
If you have not tried it: UNPLUG THE SET FOR A WHILE then plug b a c k and see if helped-----what can happen if power outage is microprocessor in set gets confused.
Let me know if questions or if this helped.
Mar 23, 2012 | Hitachi P50V702 50 in. Plasma HDTV
Toshiba 32AF44. While watching a baseball game yesterday, the volume bar appeared by itself and scrolled down to zero. The bar will not disappear. It's like someone is holding the down button. Tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 04, 2017 | Toshiba 32AF44 32" TV
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Picture black out
Like your computer a tv has the same type of circuits, & sometimes they get glitches, maybe, but i feel you might be starting to have a problem in the 'DMD" board in your tv. Maybe not; unplug tv for 10 min to 24 hrs. I am a mit factory auth tech. good luck,.
Jan 05, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
