Question about Microwave Ovens
Jvm48 I want a turntable for my microwave? JVM 48 007 built May 1985
  • 958 Answers
SOURCE: I have a Whirlpool AMW545
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Posted on Jun 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: turn table/Spacemaker Microwave
TO jatcat007
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly. (See below)
We're happy to help and we appreciate your thoughtful rating of our answer.
TO demps61
Chances are you have a bad door switch or loose door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: removal of a GE spacemaker Microwave oven model
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded views and order parts and accessories here.
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: spacemakerXL microwave oven JVM 1630
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
g
Posted on Sep 29, 2010
JVM 1850, microwave Turntable does not turn, all other functions appear normal
heatman101 ';
Apr 25, 2011 | GE XL1800 1100 Watts Microwave Oven
Removal of a GE spacemaker Microwave oven model JVM48
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
SpacemakerXL microwave oven JVM 1630 turntable in microwave not working
heatman101
g
Jan 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We have a JVM 1443bk02 ge microwave. Today the turntable stopped working. You can depress the key pad on/off button but that makes no difference for the turntable. How do you test to make sure it is the...
The problem with the turntable could be the following:
  1. Gummed up lubrication or bad bearings. Check to see if there is any food on the turntable spindle.
  2. If that is ok, check to see if the belt is loose or broken.
  3. If that is ok, check the motor. A meter will confirm whether there is power going to the motor, when you depress the keypad on button. Use the AC Volts setting, if you have about 21 VAC and the motor does not work, then the motor is bad.
Jan 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
Jan 28, 2009 | Microwave Ovens
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Turntable does not fit on coupler
The correct part number is WB06X10144. Was that the number on the plastic bag it came in?
You can order it here for $7.37 and see a photo of it here:
Aug 15, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
