Question about BenQ FP71E 17" LCD Monitor
Monitor fails during use
The monitor fails during use, timing is straight away to 5-6 hours after switched on. When it is about to fail the display goes darker and then it goes to black. Then it must be left for a while before it will work again. Please help
    Brigadier General:
  • 6,966 Answers
Hi, From your description/post, it would seem that something is overheating in your monitor. It is possible to be a cold solder joint or a component starting to fail. Since this involves component level repair, use of a VOM and a soldering iron, it sort of limits a do-it-yourself repair not unless you are comfortable working in such an environment and with such tools and equipment. A sure sign of cold solder though is if when it is jarred it turns itself on. The "growing darker" possibly indicates backlight fading. You may need the services of a qualified professional to have this repaired. Good luck and kind regards. Pls post again should you need further information.
Posted on Aug 07, 2007
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
Screen on ma2a gateway doesn't turn on. Is it the video card?
Borrow a monitor and plug it into the VGA port. That might tell you whether the graphics card is bad.
Nov 10, 2013 | Computers & Internet
For the past few weeks my Hanns G 19 inch LCD monitor keeps having troubles displaying a screen. It constantly makes a loud sound that it repeats and it takes several hours before the green light appears...
From the description you give, this sounds like a failure in the circuit board, normally the capacitors go and the thing refuses to power up, however, the fact it defaulted to a low resolution indicates that the actual board is in some way failing, possibly a damaged circuit, or component.
I would think it could be repaired and it may be a simple job for someone who can identify the failing component, however, I think that the cost of getting it repaired would outweigh the cost of replacement
Jun 22, 2011 | Hanns.G Corporation Computers & Internet
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
Monitor will not work.
This monitor was released in 2004, due time to check for bad caps with bulging top in the power supply, post back waht you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 27, 2010 | Acer AL1912 19" LCD Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
BenQ FP71E 17" LCD Monitor Logo
235 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
