FixYa.com
Tags:
Paradyne SCP 8417
SCP problem
posted by walloood on Aug 07, 2007
Dear,
Kindly be informed that i made Save and restore upload to an FTP server then i made download to the same file to the DSLAM.
After that i lost the communication to the SCP and the SCP status became:
1- Always on the test mode( test LED is only flash)
2-If i tried to console it it enters me to vxworks mode not the Agent mode.
So kindly advise.
Regards,
Waleed Morad
Business Team; Network Engineer
NOOR Advanced Technologies
Mobile GSM: +20 10 1725256
Land Line: +20 2 7492236
E-mail: telewalid@yahoo.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 22, 2007
FixYa! (100)
Zt3000
Rank:Guru Guru
Rating: 86%, 281 votes
What have you done to resolve this issue since your post?
My instinctive knee jerk reaction is that the FTP format was incorrect.
Meaning, an FTP'd file can be set for either an ASCII (7bit, 8th bit being used for error control or internationalization (extended character sets or codepages) OR a binary (all 8bits are significant) transfer.
My guess is one of two items, either the wrong FTP parameter was supplied (or defaulted) in the transfer which corrupted the file, OR the FTP server re-interpreted the FTP file which stripped off some bits. Either way, you are left with a non-functioning card and a file that doesn't actually represent the original binary file.
I wonder if you had previously set a management address to your SCP prior to this, or is this a newly powered up card?
My first thought would be, if the card doesn't come out of "test" mode in one hour, I'd remove it, let it rest a few minutes, then reinstall.
If the "test" led keeps flashing, I'd hook up your PC (and serial port) to atempt communication via the management address web interface(assuming you had set an IP earlier).
If no communication occurs, I'd try to set an IP via the CLI, despite the "Test" flashing. Then attempt the web interface.
The chances of this working are slim, but hey, you can't make it any worse.
Otherwise, your only other option is to call Paradyne at 1-800-870-2221, (since they can burn you a fresh EEprom)
ZT3000
"Beta tester of "0"s and "1's"
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Concentrators and Multiplexers problems?
problem
haw to dawnload pci simple... Answer This...
minilink
Dear sir, I have a problem in... Answer This...
how to remove manually...
how to remove manually... Answer This...
INCOMING VOICE VERY LOW
how can i adust the volume as... Answer This...
basic information regarding G4...
we have installed g4 mux but i... Answer This...
Repair Service
Find Concentrator and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
