Ricoh sp1000sp No word appear when printing?
  • 58 Answers
Blank Copies
Possible Cause
Poor drum sensitivity.
Laser optic components are out of position.
The proper bias voltages are not applied to the toner application roller and/or the development
roller.
The proper current is not applied to the transfer roller.
Action
1. Print a test pattern, and open the cover in the middle of printing.
2. Check to see if there is toner adhered to the drum surface.
If there is, do the following. If not, go to step 3.
Check to see if the cartridge is correctly installed.
Check to see if the transfer roller is correctly positioned.
3. Check to see if the cartridge is empty. If it is, replace the cartridge.
Posted on Apr 29, 2013
How can i fix the 'replace toner cartradge 'which is show in ricoh printer 4210
Please follow the steps to replace the toner cartridge on the attached link: http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001037/0001037078/view/hardware/unv/0084.htm
http://www-it.desy.de/systems/services/printing/help/Manuals/Ricoh/SP-4210/Manual/hardware/unv/0098.htm?lang=en;view=print
If the message Replace Print Cartridge remains, it means that it is not the correct toner cartridge, replace it with the correct one. If Reset Print Cartridge message appears after correct replacement, it means that the toner cartridge is not set correctly or not installed. Set the toner cartridge correctly. If the cartridge is installed, close the front cover and turn the power switch to off and to on. If the message appears again, contact your sales or service representative.
Apr 17, 2017 | Ricoh Office Equipment & Supplies
Ricoh aficio 1800 .why copies are now black lines appear from top to bottom?
I guess you talk about Ricoh MP 1800.
The Black lines on the bottom appear because the copier has made more than 60,000 prints or more if new.
If it's bought used, than it has made 60,000 or more prints from the last change of the drum and the drum cleaning blade. For the print to be clean again, it will need to be changed the drum and drum cleaning blade. This copier as all other copiers have parts that have a yield.
Aug 25, 2016 | Ricoh Aficio Office Equipment & Supplies
What do I do ? i got code SC981-00 0N RICOH 450e
[SC981] - poor connection between BICU and MSU (HDD controller)[
[SC981]- poor connection bet
Aug 20, 2014 | Ricoh Aficio 450e Black and White Copier
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Jun 22, 2010 | Ricoh Aficio 2018 Copier
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Center and margin lines are appearing in a booklet.
rpcs driver= printer properties--printing preferences--print settings--add/change custom settings---edit--draw border.
May 07, 2009 | Ricoh Aficio 450 Copier
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Problem getting the Ricoh Aficio CL12000N Printer to print files
Hi, Sorry you are having problems,
Ok, well, that sounds to me like you have a new version of Adobe Acrobat. And, well, the new version of Acrobat works with more and more options and bigger and more complex documents.... And.... well, your G3 and the Ricoh printer just can't handle these files.
So, what is the solution other than buying a new computer and a new printer, which would certainly solve your problem, ?
What I recommend is print pdf files as images, you will find this option in the print dialogue box, unfortunately, i don't have access to a Mac OS 9 machine to take snapshots to show you, but, if you snoop around the print dialogue options, I'm sure you'll find ( Print as Image ) and that feature really reduces the weight of the image you are sending to the printer.
Nov 11, 2008 | Computers & Internet
22 people viewed this question
jasbo
jasbo
