Wm2016cw Door won't close
sonicboomele
  • 1557 Answers
SOURCE: tape door won't close i
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Posted on Sep 12, 2011
machinetech7
  • 1344 Answers
SOURCE: amana he washer door won't close
Bad lock mechanism, without proper model number I can't give accurate instructions.
Posted on Jun 23, 2012
caroldon
  • 17130 Answers
SOURCE: Door won't close
Check on this visual link: door lock
Posted on Jul 06, 2012
Testimonial: " Very straight forward although I thought there might be a quick fix. Off to the parts store tomorrow."
SOURCE: rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Posted on Aug 12, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: detergent door won't close, dishwasher won't start
    Contact a professional technician to see if the spray loaded action needs to be replaced with a new cup area.
    Posted on Aug 14, 2012
    GLTF1240ASO Front Door Won't Lock/Close
    Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
    You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
    Jun 04, 2013 | Washing Machines
    1987 Oldsmobile Sierra door won't close...like
    Sounds like the door latch is stuck or broken.
    There is a gear in the side of the latch that turns when it hits the striker bolt on the door frame.
    You can try taking a screwdriver and pushing on the gear to see if it will move. You can look at one of the other doors to see how it is supposed to work.
    Apr 15, 2013 | Cars & Trucks
    The door mechanism is stuck in the closed position and the door won't close
    Push in the door button. While pushing in the button, take a screwdriver and pry up on the door mechanism on the end of the door. Should unlock and allow the door to shut again.
    Feb 18, 2013 | 1999 Chevrolet Lumina
    My Baumatic larder fridge won't go cold the fan and the compressor is working but the temp won't go below 16 degrees
    Check to see if there is ice built up around the door preventing it from closing and sealing properly. This can happen if the door isn't closed all the way at times.
    Jan 26, 2013 | Refrigerators
    Door latch
    see this causes and fix it. God bless you
    Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
    Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
    Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
    Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
    Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
    Button If the microwave door won't open the button might be broken internally. The button can be replaced.
    Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
    Oct 15, 2012 | Samsung SMH9187 Microwave Oven
    Moisture on the door of my LG WM2016cw
    washing machines do do this its all depends on the atmosphere, if it's excessive clean out the tray were you put the powder in as this is where the washer gets it air flow from, if it stays damp in there it will show on the door glass.
    Jul 14, 2017 | LG WM2016C
    Rear passenger door won't stay closed
    Jul 29, 2012 | 2003 Chevrolet TrailBlazer
    Door won't close
    Jul 05, 2012 | Whirlpool Dishwashers
    My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
    Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
    Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
    Washing Machines Logo
    Top Washing Machines Experts
