Question about Bosch DKE 9306 / DKE 9302 / DKE 9307 Kitchen Hood
Extractor hood could you please tell me,i bought a bosch extractor hood i have only got it unwrapped,does the back of it come of for easier fitting to the wall
  • 72 Answers
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Posted on Dec 27, 2009
Galvanized nipple broke off in fitting
Hi grumpy, W/D here.
The easiest way to get a broken nipple out is to use a nipple extractor. It works like a bolt extractor, but has lobes that extend when you turn the end. I bought a set at a piping supply house for ~$10. This has 3/8", 1/2" and 3/4" extractors in it. If you do more than just a little pipe work, they're worth buying. I don't know the cost for a single extractor but they should be available too. Call ahead!
Best regards, --W/D--
Jan 14, 2011 | RTO Southland Pipe Nipple 10201 Galvanized...
Bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Mar 29, 2010 | Bosch Washing Machines
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
How to install a kitchen hood extractor
Use the template that came with the hood, mark holes on wall and then drill and insert wall plugs. Offer unit up and screw from the inside.
Nov 15, 2009 | Kitchen Ranges
Bosch TD WTA3000 can't find reset button
YOU NEED take out hood cover 210162 in the back dryer.
Oct 06, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Bosch Extractor Fan model DKE945DGB
One way to check is to track down a schematic of the parts. That will often give you a good idea of there the part attaches and how.
Feb 01, 2008 | Kitchen Ranges
Bosch DKE 9306 / DKE 9302 / DKE 9307 Kitchen Hood Logo
458 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
