Question about Canon Pixma iP6600D InkJet Photo Printer
Yellow not printing in Canon iP6600D printer
How to isolate the colour that doesn't print properly and print few pages in that colour (eg if yellow is not printing right...set out a full page of yellow background and print on high quality setting until yellow starts to print ok). How can I do this as my printer issn't printing yellow & I have done 5 or 6 deep cleans
  • 58 Answers
In the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Posted on Apr 29, 2013
ginko
  • 19396 Answers
SOURCE: canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Posted on Nov 25, 2008
  • 5 Answers
SOURCE: Printer problem, yelloow head not working on my canon
I stumbled on an ebay seller who is selling cleaning solution for print heads. Canon print heads are removable without special tools.
I gave mine a clean with metho, as I figured that it could not get any worse and I got the gist that I was going to have to replace the printer anyway.
I cleaned it with metho (just the bottom of the print head) and ran the clean print head function twice from maintenance and it is not working perfectly.
I do recommending taking this advice with caution as I do not know if this process could cause further damage or not work.
Posted on Nov 28, 2009
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
canontech
  • 1219 Answers
SOURCE: The printer is recognising that
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Posted on Aug 04, 2011
pheireith244
  • 310 Answers
SOURCE: The yellow won't print. It
You need to align strongly....... If it doesn't work properly .... remove your catridge and rub its head neatly .. and replace again..... thanks
Posted on Aug 18, 2011
Canon iP6600D printer keep printing in Blak ink only
1st option, set the default profile in the printer properties. if it doesnt work. this will change all the settings that you might missed to check to go back to factory setings. also, check if your color cartridge is ok and with enough ink and not dis abled
2nd option, run any 3rd party software that can fix some windows system files or something like that. try to scan pc for viruses
3rd option, reformat your pc. maybe windows files that allows your printer to work are having problems or corrupted, base on the thing that you mentioned that it goes back to the grayscale settings
May 27, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
Yellow cast when printing from canon mx850 - I see this problem has been described before, where do I find the answer?
The way inkjet printers work is they mix the limited amounts of colours available from the cartridges, by printing in layers, to get the desired colour. A lot of the time when it appears off colour its because one of the other colours isn't printing properly to show create the correct 'mix'.
This can either be because the colour is low, or because there is a blockage somewhere. I would suggest removing the cartridges & reinserting them, then performing maintenance which i believe can be done on the printer itself by pressing the menu button, finding 'maintenance/settings' pressing OK, then going to 'maintenance', followed by doing a 'cleaning procedure'.
More info here: http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/MX850.aspx?faqtcmuri=tcm:14-605698&page=1&type=faq
If this doesnt help, try the same thing but choosing deep cleaning.
Hope this helps.
Mar 16, 2011 | Canon PIXMA MX850 multifunction InkJet...
How do you go about cleaning printer head
there is a cleaning utility "printhead clean" and printhead deep clean" under "maintenance" in the "printer properties". Try that first. If that doesn't help and there is definitely ink in the cartridge(s), you can remove the cartridges and soak the printheads in 5mm of hot water for 1/2 hour or so. DRY WELL then install back in printer and run "printhead deep clean".
Another way is to isolate the colour that doesn't print properly and print few pages in that colour (eg if yellow is not printing right...set out a full page of yellow background and print on high quality setting until yellow starts to print ok). This wastes less ink than the cleaning utility.
good luck with it
LC1000
www.inkbank.com.au
Dec 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have an Epson Stylus C110 Injet printer and it would not print the colours properly. Eg. it is not printing the yellows properly by printing too much purple. I can't get it to print the colours I want.
run a maintenance page on it..
goto your printer panel..and then selct maintenance..
and print maintenance page to clean the cartridge..after printer get your cartridge and wipe it on a wet cloth to avoid clog on the nozzles...
May 18, 2009 | Office Equipment & Supplies
Printer wont continue printing if ONE cartridge is empty
Sorry to say this, I had a Canon Pixma and it wouldn't print unless you replaced empty cartridge, although I did have some success for a while longer by pressing OK button?
Feb 27, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D - ink problems
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Oct 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
477 people viewed this question
old marine
old marine
