Question about Sewing Machines
Singer promise 1409 has jammed, cleard out all thread but it still wont move front or backwards.
Jammed have cleard all threads iside mahine and bobbin area still is jammed up
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Posted on Aug 08, 2008
  • 9 Answers
SOURCE: my thread in the bobbin keeps getting jammed up
Here are some possible solutions:
1) Try a new bobbin, and if you wind your own, make sure it is wound very tightly
2) Take the bobbin case out and make sure there are no stray threads stuck down there, they can wreak havoc! To do this, unscrew your throat plate and lift the bobbin case out. Then use your lint brush that came with the machine, or another small soft brush and give it a thorough cleaning under there.
Hope these help!
Posted on Mar 17, 2009
bargainbox
  • 1388 Answers
SOURCE: I'm working with a singer touch & sew II model
Loosen and and remove the needle, cut top thread. You will need to remove the bobbin case, carefully cut threads below and around, then ease the mess out and away....tidy it up carefully later.
Now to tension and etc Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 19, 2009
  • 36 Answers
SOURCE: Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
Posted on May 25, 2010
  • 539 Answers
SOURCE: Have a brand new Singer
Check needle.
Bent? Replace it!
Always thread needle with presser foot in up position. If presser foot sitting flat against feed dogs when you thread the needle eye, the tension disks will not allow thread to locate itself into tension disks at all, in which case, no matter how much you adjust settings - nothing will do any good UNTIL you thread needle eye with presser foot in up position so tension disks can work.
If you don't think that is problem, then set machine on a straight stitch with straight stitch foot, set tension on 4, stitch with on 4-5, test light to medium woven fabric with size #11 needle to test.
Always clean shuttle and feed dogs for broken thread or lint, and put in new needle before getting panicky.
Jimmy
Posted on Mar 31, 2012
Singer 3116 machine has jammed. Can not turn wheel to move needle.
make sure there isn't thread jammed in the hook take out the bobbin case and look
Nov 14, 2017 | Singer Sewing Machines
When threading machine, thread won't stay in place at step 4, so when I move thread to step 5, thread comes away. Only bought mchine in March.
When threading the upper thread, be sure to always raise the presser foot. This releases the tension disk and allows the thread to seat properly.
Here's a video that may be helpful:
Singer Fashion Maker 1409
May 15, 2016 | Singer 1409 Promise Sewing Machine
Why is he hand wheel frozen
Obviously, something is preventing it from turning, and that could be something in the inside or the outside. First, make sure that your bobbin and bobbin case have been correctly inserted. Next, remove the cover over the thread path--it's usually removable to check for broken threads and cleaning--and it's either one or two screws. If it's one, it's at the back of the machine. If it's two, there's one in the side, usually covered by a white disk for cosmetic reasons. Press on one side of that disk with a flat blade screwdriver and the other side will pop out enough to remove it. If your bobbin is not jammed, it's probably threads that are preventing it from moving.
Aug 21, 2014 | Singer 1409 Promise Sewing Machine
Machine is Jammed
Try turning the wheel to the right end manually----briskly back and forth to loosen thread that are caught in the bobbin. Remove bobbin and clear threads. If none, remove plate below needle to see if thread or fluffy threads are clogged below. No good...have it serviced by a professional.
Apr 06, 2014 | Singer 7422
Singer esteem
when you have a machine jam up there is something wrong with the parts
inside, only a sewing machine shop can tell more after they check the machine.
Apr 16, 2012 | Singer 3116 Simple
My singer 2500 has the needle jammed
Undo the needle clamp and turn the balance wheel backwards slowly and take the needle out, then check for jammed thread
Aug 12, 2011 | Singer Sewing Machines
My machine is jammed. it will go backwards but
It usually is stuck thread and it might only be the smallest piece, run a pin around the inside of the raceway and see if anything comes out.
Mar 23, 2010 | Singer 3116 Simple
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
