Question about SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter
Problem in SENAO High Power 200mW USB WiFi 802.11bg Adaptor
I've been using senao before and it was working well, but i gave my adapter to my cousin and purchased a new the same unit. when i tried using the new one it always give the note that limited or no network coverage... but the signal shows excellent strength.. i also tried uninstalling the driver and installed it again but the same problem i am getting.. can you help me on this? thank you very much.
    Problem Solver:
  • 51 Answers
There are a few things you can do in this case. First, I would check to see if you have your network profile set up correctly. This is done by going in to your wireless properties and checking the profile to see if the encryption password is correct as well as the encryption type and so on. Next, you can go in to the device manager and make sure the wireless adapter is recognized and enabled. If you need help doing these things, let me know.
Posted on Aug 17, 2007
How to secure my home network wifi how to put a password?! it appears that it's Unlocked..
Wireless network passwording is done at the router, in the wireless setup area. Log into your router using the admin userid and password. Go to wireless settings and there you will see the option to set a password for the wireless network. One you set the password and save it, all devices that connect to your network wirelessly will need to be reconnected to the network, using the password you selected to gain access to the network.
Sep 17, 2016 | SENAO High Power 200mW USB WiFi 802.11bg...
Booster for senvo358
Go to this LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 01, 2010 | SENAO High Power 200mW USB WiFi 802.11bg...
Slow downloading speed
Make sure that your port is open on your router to allow the connections. This setting is under the options in the software. You can follow this from the site to walk you through:
http://www.utorrent.com/documentation/connection-setup
That will allow you to connect to more peers. Also, make sure you have more seeders in the swarm. Good luck!
Oct 22, 2009 | SENAO High Power 200mW USB WiFi 802.11bg...
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
Nov 14, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Reconfigure wireless card
I believe he's wrong. But the wireless card which only does B needs to match the router which could be A,B, or G. And B has some serious range limitations. You also need to manually address the card or the router has to be configured for DHCP. Get past those issues and it should setup normally.
Oct 15, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Problem with Senao and Vista
port forwarding...
low download speed....
Dec 05, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO wireless adapter not working
I assume you have the unit set to alocate ip addresses automatically in other words the dhcp is set to enabled in the settings. If so it maybe that the address is registering wrong, you can either click start>run> then type ipconfig /flushdns, or uninstal your wireless network card in device manager then restart the pc to automatically install it again as this will set it back to default, but remember to make sure obtain ip address automatically is enabled in the adapters properties on the tcp/ip properties.
Aug 06, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter Logo
163 people viewed this question
Top SENAO Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
