Question about Sea-Doo US 2008 RXP 215
Code p0505 - Sea-Doo US 2008 RXP 215
Alfa 156 2lt JTS fault codes P0120 & P0505 are they an easy fix?
p0120 means you have a throtle position sensor problem could get expesive if throtle body is bad p0505 is same problem it means throtle idle controle valve problem hmm short bad ecm or bad throtle body hope this helps
Nov 27, 2012 | Cars & Trucks
1999 dodge durango 5.2l code po505
P0505 - Idle Control System Malfunctionxicon.jpghttp://engine-codes.com/p0505.htmlForum CodePossible causes- IACV-AAC valve harness is open or shorted
- IACV-AAC valve poor electrical connection
- Faulty IACV-AAC valve
Read more: http://engine-codes.com/p0505.html#ixzz1zVJIt34L
Jul 02, 2012 | 1999 Dodge Durango
How to fix code P0505 code on 2000 kia sportage?
P0505: Idle Air Control Valve System fault, Code P0505
-Vacuum leak
-Dirty throttle body
-IAC motor defective
-Poor electrical connection to the IAC valve, hope this helps and good-day !
Mar 29, 2012 | 2000 Kia Sportage
P0505
Its the IAC idle air contorll unit its on the air horn and controlls the air flow at idle This code is saying that something is malfunctioning it is not saying at what RPM it is happening at there is 5 or 6 differant codes for this and they run from P0505 thought P0509 but if you are geting P0505 i would just replace the unit but check the connection to it first it may be a bad connection it dose get weather and heat and that cerates problems with contacts
May 07, 2011 | Honda Civic Cars & Trucks
2003 jeep grand Cherokee with the 4.0 has a code
P0505
Idle speed continues to vary greatly from the target speed
(2 trip detection logic)
IAC valve is stuck or closed
Open or short in IAC valve circuit
Open or short in A/C signal circuit
Air intake (hose loose)
MARKO
Aug 11, 2009 | 2003 Jeep Grand Cherokee
Code P0505 on 1999 Acura TL
this code make reference to low idle engine,maybe the throttle body is dirty , air filter clogged, vacumm leak , pcv valve clogged, check for thoses
Apr 23, 2009 | 1999 Acura TL
1996 dodge ram 1500....p0505
p0505 is a code for your IAC (idle air control valve) located right below the TPS (throttle positioning sensor). Beware it is not necessarily the sensor. If you use a test light on the connection coming to it while the vehicle is running and rev the motor each terminal (probably four) should flash. In this case it is most likely your sensor. If not it is in the wiring or your pcm.
Feb 24, 2009 | 1996 Dodge Ram
1996 dodge ram 1500 p0505 code.whats that mean?
Hi there P0505 code is an idle control system malfunction.
Jan 24, 2009 | 1996 Dodge Ram
Sea-Doo US 2008 RXP 215 Logo
104 people viewed this question
Top Sea-Doo US Boating Experts
Richard Lilja
Richard Lilja
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
