Question about Garden
Craftsman yt 3500 22 hp
My brand new 'out of the box' mower will not move. The transmission will not engage in forward or reverse. The pedal moves freely and will not spring back when you take your foot off it.
SOURCE: Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Lawnmower wont move in fwd or reverse
Is the brake sticking. On my craftsman mower there is a bar under the brake pedal that pushes back a lever when starting. And the lever sticks. I have to reach underneath and pull the lever forward and then the mower goes. I haven't found a solution to that yet.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
