Question about Garden
Simoniz lr54005 need to replace the speed gun but cannot find it online
3 Suggested Answers
SOURCE: Simoniz pressure washer cycles whe not spraying?
This condition is normal.
Posted on Jul 02, 2009
  • 174 Answers
SOURCE: S1600 Simoniz gun - I took it apart and I have a
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Posted on Aug 12, 2009
Testimonial: "Thanks - a little frustrating thinking there must be a simple fix - buying a new gun that will also breakdown - that's where they get you. "
What replacement battery can I get for my simoniz 18vbuf cordless polisher
You can either contact the people that made it and pay an outrageous price, or you can go to a place like batteries plus and buy a replacement that is what I call a re-pop for about half the price of the maker. You'll find a link to them attached
Jun 02, 2014 | Simoniz 18VBUF CORDLESS POLISHER CORDLESS...
Gun leaking when i use my simoniz 1900 pressure washer
The simoniz 1900 gun is very poorly designed. It is held together by a dozen small screws.
First open the gun by taking all the small screws out. No worries, it is much more simpler and worse constructed than a 5-year-old toy gun.
After opening the gun, you will see there are only two parts inside. One at the front connecting to the wand, and one at the back connecting to the hose. The trigger is looped over the joint part.
Make sure the back part is firmly fitted into the slot properly, otherwise it leaks. And be careful don't lose the spring, because there is no object to hold it in place.
Now all you need to do is to put all one dozen small screws back in. Don't over tight the screws, otherwise they will punch through the plastic cover.
Now your simoniz 1900 gun is fixed but it leaves you wonder which 10-year-old designed it?
Jul 30, 2012 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
Hy; I have a karcher 580 I had to replace gun complete so I bough a simoniz xe01-001 at simoniz.osirus.ca/ for your info 69$ complete ***.I install NOW I get pulse up & down ONLY when trigger is press...
Most likely problem is that the tip is too small causing Unloader to bypass or restriction/debris in tip. Install clean tip of proper size or 1/2 size larger (example from 2.5 gpm to 3 gpm ) to prevent slow pulse. If tip is clean and /or larger tip does not help, Unloader may be failing if the unit has a good deal of hours or if machine is left running for long periods of time without spraying. Try lubing the internal parts by removing both hoses and installing a short piece of water hose to intake and slowly inject light oil into pump by pulling on the rope slowly to **** in the oil until it comes out the pressure side. This will displace all the water from inside the pump. Leave overnite. There is a kit sold on ebay to help facilitate the infusion of oil but no need to get fancy. Unloader repair kit is usually available if all else fails and is easy to install. Good holidays
Dec 12, 2010 | Karcher 2500 PSI Pressure Washer
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Mar 31, 2010 | Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
Aug 11, 2009 | Karcher Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
