Question about APW Hot Dog Steamer/Bun Warmer
Replace thermostat for nemco 8300
Replacing thermostat
HOW DO I WIRE POWER SWITCH
If it is only two wires just get a regular toggle switch.
Dec 03, 2013 | Nemco Hot Dog Roller Grill Narrow Electric...
I have a Nemco 6550a food warmer. I removed the thermostat control and disconnected the wiring....An employee came up and distracted me and well now i can't remember which sure wire goes where. Theres...
Sounds like a standard three wire thermostat. The Blue will go yo terminal marked N (neutral) and the two yellows will go to L and SL (live and switched live) To determine which yellow is the live feed carefully position the wires so they are not touching anything or each other and turn the warmer on. Test between the blue cable
and the yellow cables to determine which yellowis the live. Connect this cable to the L terminal and the remaining yellow to the SL terminal.
Oct 01, 2017 | Heating & Cooling
I want a dicer that lets you make 1/2" and bigger chunks. Anyone?
This one allows 1/2 inch -3 inch chunks
http://www.zesco.com/Nemco-N55500-3-1-2-Cut-Free-Standing-Easy-Chopper-Dicer-Complete-pz518D02912.htm
Jan 14, 2013 | Home
I have a dell dimension 8300 and the factory monitor has horizontal lines flickering all over, with intermittent fuzzy haze. Do I need to replace my graphics card to fix this problem? I already downloaded...
Borrow another monitor / if the same download latest vid card drivers / install. (Check cable as well)
If it fixes it either get monitor repaired / replaced.
May 11, 2010 | Dell Dimension 8300 PC Desktop
I am looking for a vent cover for the dryer that is a dryer mate by nemco. It is 5" by 5" square. Where can I locate one?
I had the same problem and the ones from Lowes, Home Depot etc doesn't fit. I called Buildersbest who makes the vent to ask where I could buy 1-8-U-VENT-SAFE (1-888-368-7233) and they sent me replacement louvers for free!
Nov 22, 2009 | Dryers
Can I convert the ceiling fan and light fixture switch to individually controled switches
only if there are two circuits going to the fan. or two switch legs going from switch box to the fan.
Mar 09, 2009 | Nemco Heating & Cooling
APW Hot Dog Steamer/Bun Warmer Logo
Top APW Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an APW Kitchen Appliances - Other Expert? Answer questions, earn points and help others
