Question about Rain-X Latitude Wiper Blade
Replace rear wiper blade - Rain-X Latitude Wiper Blade
2011 equinox rear wiper replacement
I just replaced mine. Lift the rear wiper up as far as it will go. which is not very far. Place your fingers on each end of the wiper and pull down. The blade is held in place by a clip. Gentle pressure will downward toward the window will cause it to disconnect. An extra pair of hands to hold the plastic cover up helps. Note the orientation of the blade when you disconnect it. The replacement blade may have a clip on it which may need to be removed. Place the replacement blade in the same orientation as the one that was removed and clip back in place.
Sep 16, 2012 | 2011 Chevrolet Equinox
Tip
How to maintain your rear wiper blade on a Honda Jazz/fit
When trying to purchase rear wiper blade rubber replacement i could not find a listing for it,i also noticed that the replacement blades for the front needed only a couple more inches of length for the left hand side cutoff to be long enough to do the rear as well ,you would think the manufacturers could have given you that extra as a bonus. Anyway when replacing front wiper blades,as you should at least once a year,rotate the shorter blade to the rear wiper it is the same size, just pull the end of the rubber insert slightly bending it away from the frame and it will slide out,better than having a rubber that is perished hard,how many cars do you see with rear blades that are useless, maybe other makes might also benefit from this.
on Dec 22, 2010 | Honda Fit Cars & Trucks
I need to replace the windshield wiper blade
The 1998 Dodge Grand Caravan takes 28" wiper blades on both sides front and a 18" rear wiper. See related links below for more information. Since there are over 22 different wiper arm attachments, do not buy wipers just by length only - be sure to lookup exact wiper blade part numbers by vehicle make, model and year for the brand wiper you decide to purchase. This ensures correct length AND correct attachment.
1998 Dodge Grand Caravan Wiper Blade Size Options w/Correct Lengths & Attachments
1998 Dodge Grand Caravan Wiper Blade Installation Videos (hook front, hook rear)
Sep 09, 2011 | 1998 Dodge Grand Caravan
Replacing 2004 gmc envoy xuv rear wiper blade
Replace the blade and the blade holder. These days everything but the arm gets changed....and gone are the days of just replacing the rubber...
Jul 19, 2011 | 2004 GMC Envoy
CHANGING REAR WIPER ON 2008 OUTLANDER
These are available at the dealership. There is one way though. You can get a 21" RAIN X wiper and i just cut it down to size. The grooves on a RAIN X will fit up to your rear wiper. As far as replacing it although it looks more difficult at first glance it it every bit as simple as the front wiper blades. It's a simple pop off. You can also just change rubber wiper and leave the actual blade alone. the rear is a mini blade style (this refers to the size of the rubber insert in the blade, not the actual whole blade being small.) You can replace the rubber using an Amcor blade or any "mini" blade. Puchase the biggest one they have, take out the rubber wiper and just cut to size. You can change the rubber many times off of one blade thus saving you a bunch of money.
Mar 17, 2011 | Mitsubishi Outlander Cars & Trucks
How do you replace the rear wiper on a 2009 Scion XD?
You can make use of following procedure to replace rear wiper in ur scion xd.
Pull the rear wiper arm away from the rear window in order to access the wiper blade.
  • Locate the hinge where the blade mechanism meets the wiper arm and squeeze the plastic tabs on the blade in order to release it from its locked position on the arm. In some cases, instead of tabs, there is a small button that must be pressed to release the wiper from the arm.
  • Detach the blade from the arm and slide the old blade out. Insert the new blade into the wiper arm and lock the blade in place.
  • Return the wiper arm to its set position. Before driving, wet the window and test the wiper to make sure it is operating properly.
  • Dec 14, 2010 | 2009 Scion xD
    Having trouble removing the rear wiper blade for replacement on my Hyundai 2007 Tucson.
    you can only get a replacement wiper blade from a hyundai dealer .because the centre pin is thicker than a normal blade and when you get a replacement all you do it just hold the plastic rear wiper housing and pull the old wiper blade out then push the new on back home and your done
    STRAKER1999
    Sep 02, 2010 | Hyundai Tucson Cars & Trucks
    How to replace the wiper insert at the back of
    1. REMOVE RR WIPER BLADE
      1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
      2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
    1. REMOVE REAR WIPER RUBBER
      1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
    1. INSTALL REAR WIPER RUBBER
      1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
    b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
    c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
    Sep 12, 2009 | 2005 Toyota Matrix
    Rear wiper blade
    I went to a Honda dealer and bought a replacement wiper blade (rubber part only) for about $6, and the guy in parts came outside and changed it for me. You slip off the rubber blade only from the wiper assembly and then slip in the new blade.
    Jun 06, 2008 | 2003 Honda Pilot
    Rain-X Latitude Wiper Blade Logo
    85 people viewed this question
    Top Rain-X Photography Experts
    Tony
    Are you a Rain-X Photography Expert? Answer questions, earn points and help others
