Question about Nokia 3230
Camera when i capture a image it shows that memory full close other application and try again... i dun noe wad to do
  • shivanes nadarajah Aug 07, 2007
    After deleting all also the phone is showing memory full close some application n try again
    Guru:
  • 120 Answers
You need to delete files from your memory. Pictures take up a lot of space, to be able to take additional pictures you should probably delete some of the ones you have saved in the gallery currently. Delete files to make more space and you can take more pictures.
Posted on Aug 07, 2007
SOURCE:
We cannot get our images off of the Nikon Coolpix S570. I have a Mac (OS 10.4.11) - am linking with the USB standard cable that comes with the camera. The Mac can see the Camera in devices (about this...
I am not sure if I can help but what I would suggest is first of all disconnect the camera from the mac and then if you have iphoto go to preferences and make sure that iphoto is the application that is activated when the camera is plugged in. Then close the preferences. Now connect the camera to your mac. If you do not have iphoto you can use image capture which is in the applications folder. Hope this helps.
May 27, 2011 | Nikon COOLPIX S570 Digital Camera
My phone samsung b7722 duos.Opening the files,images, capture the camera and Dictionary at the time this mobile was asking ( Not enough memory close sum application and try again later )
y phone samsung b7722 duos.Opening the Multi software at the time this mobile was asking ( Not enough memory close sum application and try again later )
Apr 20, 2011 | Samsung Star GT-S5233 Cell Phone
I appear to have lost all my holiday photos due to a crash within the camera when the memory was reading full. Although the camera is not recognising any images on the card It still has a message saying...
you can try to get your images if you use an adapter for the memory card that connect to your computer then there is an application that recover files from a memory card
Hope it will help
Aug 22, 2010 | Fuji Cameras
It says that Memory full! close some application n try agn. for capturie an Image.
Just a shot in the dark, but I have had users that have had this same issue because that had multiple applications loaded up on their phone.
One thing you could try it to un-install a couple of applications that you do not use all that much (ones you can get back easily if needed) this would automatically free up some memory and allow you to test out capturing an image.
Just shutting down an application will not free up that much memory, you will have to actually delete or un-install a few things to make a difference.
There are a variety of things you can do to free memory, like deleting pictures, images, ring tones and un-install apps. Just make sure what ever you un-install or delete, you first do not need or can easily get it back. I've had users think that some of these phones have a recycling bin on them like windows does :-)
Good luck and I hope this helps.
Jun 03, 2008 | Nokia 3230
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Messages say resend all the time in d outbox
This is not a question of your phone's external it says for internal or workable memory of RAM. RAM is for providing room to running application. In your phone RAM is seems stuck and you have to empty it by formatting. For that backup your data and reset your phone by entering code string *#7370# and it will work again properly.
Jan 12, 2008 | Nokia 6630 Cellular Phone
Image capture problem
try to reprogram your phone...
Feb 05, 2007 | Nokia 3230
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nokia 3230 Logo
59 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
