Question about Revo RECBH2812-1 Professional Security Camera
Wire i would like to know how to wire an RJ12 the cable is sheiled theirs a red yellow white baer?
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
May 18, 2014 | Kenwood KDC-MP538U Car CD/ MP3 Player
I need a wiring diagram for soc-n120 camera
1 2 3 4 5 6 Green Red Yellow Bare Gorund Clear
Cover
Black RJ11e color & slot. Orientation Lock Pin Down. Wire at bottom
May 10, 2012 | Samsung Security Color Camera Soc-n120 +...
I need a converter that will allow me to hook up the rj12 cables to the coaxial connections on a 16 channel revo dvr
hi;
you wan to hook up coaxial to rj12 ,if you you do that the wire of rj12 has not to exceed 3 meters
cause camera signal (video) to become weak. Camera Video signal has to be fed only to coaxial cable, coaxial cable has an insulation to prevent interference.
so if you want to hook up be sure put a shielded wire.
thanks......hope this help.
Sep 03, 2011 | Revo America Indoor Dome Security Camera...
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
We have sound but no picture on our Wii
Connect a DVD player using red white and yellow to the TV if you get picture and sound, then reconnect the wii red, white, and yellow to the same input.
If only the wii does not show video you will need new red white, and yellow cables. I would try a friends red, white, and yellow cables first even to their TV where their wii is already working.
If new cables are not working you will need to contact Nintendo as there is an issue with your wii. You can't change the wii video to progressive without a component kit, and since you have yellow you obviously don't have a component cable for the wii.
May 15, 2010 | Nintendo Wii Console
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I don't know how to re-install loose wires on my power cable
Goes in this order:
Red
White
Yellow
leave last 1 blank
Apr 25, 2009 | Computers & Internet
I have taken out my standerd sterero in ford fiesta 1996 and cut off the block dont know what wires are what and now clock dont work ant think i have blown the stereo can any one tell me what wires are...
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
Apr 13, 2009 | Car Audio & Video
Revo RECBH2812-1 Professional Security Camera Logo
20 people viewed this question
Top Revo Home Security Experts
Lawrence Oravetz
Are you a Revo Home Security Expert? Answer questions, earn points and help others
