Question about Pyle PLW12DRE 12 Car Subwoofer
How to re attach cone leads - Pyle PLW12DRE 12 Car Subwoofer
  • 1,147 Answers
They are stitched in.or do you mean how to soldier them back on to post.
Posted on May 06, 2013
Reconnecting/retiring Bose speaker cones. Inside speaker I have four coloured wires....Red,Black, Green & Orange....which connectors do they attach to on the speaker cone?
Since you posted this in cars and trucks I assume this is a bose car system. Most bose auto systems have the amp physically attached to the individual speakers. This means each speaker needs the following wires +12v, 12v ground, + signal and - signal. It also means that the head unit cannot directly drive a non bose speaker. If you are replacing the speakers and bose radio the best thing to do is to run new speaker wires. You can reuse the factory ones if you can identify which ones are what...and that may be a pain. If the bose amps are ok and you want to replace the speaker you would need to leave them connected and wire the new speaker to the wires on the bose speaker that come from the bose amp. Depending on the specific bose system there may be an actual wire that runs to the speaker from the amp but on others the amp is directly connected to the voice coil leads of the bose speaker.
Oct 13, 2016 | Cars & Trucks
Despite wiring speakers correctly they remain out of phase. I know that reversing the connections resolves this problem but it has caused problems when playing 4 speakers simultaneously i.e., I need to...
I have no idea how you determined they are out of phase. Normally if you change all of them the result is the same. Just change the one (swap the speaker leads) that is out of phase.
First assume they marked on the amplifier typically red and black connections. Then check the speakers to see if they are also marked the same way, if so match the colors.
If they are not marked you need to be able to see the cone, that use to be easy. Use a battery and connect it across the speaker leads, I use a flash light 1.5 volt battery. You may have to go to a 9v but try the 1.5 first. When you connect the battery the speaker cone will either move forward or reverse. If the cone moves in reverse when connected swap wires. When the cone moves forward just mark with the plus (red) coinciding with the battery.
Nov 28, 2014 | Audio Players & Recorders
I have the fruit and vegetable strainer attachments to my Kitchen Aid Mixer. I was processing concord grapes, and the grape seeds and skins have gotten stuck between the white plastic auger and the metal...
Put the square auger end in a vise and lock it down, get a heavy terry cloth rag and wrap it around the cone and turn back and fourth by hand, (the cone is not strong enough to take any pressure from tools) until it starts to move, then keep turning back and forth while applying a lifting motion to the cone. That,s how I get mine apart when I get orange seeds stuck in it.
Sep 24, 2013 | KitchenAid Fruit and Vegetable Strainer...
One of my leads to cone on my kicker cvr came loose how to fix it
If the lead connection broke at the terminal end, it can be resoldered. If the connection broke at the cone end, you are pretty much out of luck
Mar 06, 2013 | Car Audio & Video
2001 ford explorer packing front bearings
This is going to sound silly. Buy a bearing packer. This device is not expensive and should be available at just about any auto parts store.
It is a fairly simple device. It looks like two shallow cones mounted on a shaft. The bottom cone is fixed and the top cone unscrews from off the shaft. The shaft itself is hollow with a grease fitting on top. Just remove the top cone, place the bearing on the bottom cone and screw on the top cone firmly, but not over-tight. Attach a grease gun loaded with the desired grease and pump the handle until you see grease come out the sides. At that point, the bearing should be fully packed.
Jul 22, 2010 | 2001 Ford Explorer
Missing cone cover for floor standing infinity speakers
Those cone covers are important because they distribute the audio of the driver over a wider range. The defect will not cause further troubles nor will it get worse. Most people are capable of repairing them yourself. If you lost the old cone a replacement is necessary. You will need preferably the part number off the back of the speaker to get a replacement. Carefully measuring the diameter of the cone according to where the old glue shows it was attached will also get you the part. Just use Elmer's White glue to reattach. It get's tacky after a few minutes and the cone should sit there and dry for a few hours after replacement. Check for speaker repair parts online. You will find bunches of suppliers.
Zashiban
Jun 23, 2010 | Infinity Alpha 50 Main / Stereo Speaker
I just bot Pioneer speaker CH26861...4 wires to 2 leads...
I would tie both + from the speakers to the radio, and both - as well. This will give an equal amount of power to both speakers and reduce the chance of blowing a speaker. As for +&- on the speakers, It is usually marked on the black piece right by the terminals. As little power as you are putting to the speakers, it doesn't really matter which way you hook them up, as long as they are both hooked up the same.
Jul 30, 2009 | Car Audio & Video
My wire got pulled off my sub how can i fix it
Hello gatmanfromda,
I'm assuming you mean the "tinsel" lead going from the connector to the sub cone. In many cases, the wire can be soldered back on. It takes care and patience and you need to be sparing with the solder and prevent it from stiffening the tinsel lead. Otherwise it will tear out again when the sub cones moves out. If the cone itself was damaged when the lead pulled off, you can use silicone sealant to repair it. Again, be sparing with the silicone and allow it 24 hours to set up before trying to operate the sub. If the wire pulled off from the connector terminal, just solder it back on.
Hope this helps.
Jul 11, 2009 | Kicker CVR12 Car Subwoofer
I need picture or instruction on how to take apart a Alpine 12 inch type X subwoofer?
First pry off the rubber gasket. Then take a razor and cut out the cone, cut as close to the outer edge of the surround as you can. Then snip the tinsel leads connecting the cone to the spider. Then take your knife and cut out the spider. The cone and voice coil should now slide out. The rest of the speaker can be takin apart with a screwdriver and hammer.
Now hide from the owner of the speaker, he will probably want to hurt you.
Guy
Dec 18, 2008 | Alpine Car Audio & Video
I need radio color codes for a 2001 fordranger
The simplest way to figure out wire colors on the ford is to purchase the radio wiring harness from a stereo shop like a Metra or Scosche harness and match the aftermarket wiring color code to the opposite side (vehicle side) of the radio plug. If you are just replacing speakers, then removing the speaker from the car with the plug attached, you can easily figure out polarity. Just connect a 9v battery to the speaker leads on the speaker (NOT THE CAR) for a second will make the cone either pop out or **** in. When the cone pops out, note the polarity of the + on the 9v battery. This is the positive for the speakers. Hope this helped.
Aug 03, 2008 | Car Audio & Video
Pyle PLW12DRE 12 Car Subwoofer Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
