Question about Husky H1503tp
Husky 3 gallon air compressor
I have a h1503tp that will not start when you plug in and turn on switch just lights up but nothing happens
2 Suggested Answers
  • 33 Answers
SOURCE: motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Posted on Sep 03, 2012
How do I adjust tank pressure
By letting air out.
Remove the pressure regulator plasic cover (usually one screw) and there will be 2 adjustment screws. One is for "cut-in" pressure (to start the compressor when the pressure drops below the set point), the other is for "cut-out" (to stop the compressor once that set point has been reached.
Oct 16, 2014 | Husky H1503tp
Motor does not shut off at 155 psi
The pressure shut off switch is not working right.. I would contact husky about a replacement part
Nov 28, 2013 | Husky H1503tp
How to adjust cut in pressure on husky 60 gallon
what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
Husky 60 gallon compressor switch from 220 to 110
Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
Jul 28, 2012 | Air Tools & Compressors
I hsve a Husky 1 gallon tank 10 max psi mod # FP 202900. I was using it the otherday when it all at once started making a little noise then quit. I have unplugged it hoping it would reset, but no such...
There should be a reset button on the motor. Try that first. Otherwise, it is a bad pressure switch or internal motor problem. If resetting the motor allows the unit to start, but it just hums, shut it off right away, bleed off all pressure and try again. Let us know what happens.
Oct 21, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Sep 03, 2009 | Air Tools & Compressors
Husky H1503tp Logo
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
