Need to know how to adjust belt tension
SOURCE: hyundai 2001 XG300 tensioner pully adjustment
the belt that goes on the alt. ?? if so the tensioner is accessed from under neath the car. You will have to remove the right side tire and plastic sheild that is in place. When you look up at the bottom pulley you will see a nut head. If you lay on your back and look up at the engine, it will be located on the left or front side of the car.
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
SOURCE: need serpentine belt adjusted
You cant adjust the belt tensioner. You have to replace it if it wont provide the proper tension.
