Question about Refrigerators
Manitowoc ice machine model no QD0602A
Ice maker makes cubes with thin layer of solid behind cubes when dumped
SOURCE: Ice maker not dumping ice
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
  • 115 Answers
SOURCE: ice maker not making solid ice cubes
check your freezer temp and also if there is a water filter it might need to be changed
Posted on Dec 30, 2008
SOURCE: ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Posted on Feb 21, 2009
  • 531 Answers
SOURCE: ice maker not making ice- water leaking or cubes melting
icemaker have problem
Posted on Apr 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
We have ice maker which shows off /on mode
Make sure it's not in clean mode... needs to be in ice mode
Aug 24, 2014 | Manitowoc ID1202A-261 Dice Cube Air Cooled...
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Starts into ice making then dumps ice slurry in tray
Adjust the ice thickness sensor out 1/4 turn at a time until 3mm ice bridge forms between cubes. Clean condenser thoroughly, descale ansd sanitise waterways inside.
Jan 30, 2014 | Manitowoc QY-0214A Self Contained Ice...
My ice cubes are not solid and very thin I have had a lot of repairs for m;y ice makers. One time a tech told me the water leading to ice maker is no good. Is there anything we can do to solve thin ice...
HI.CHECK FOR WATER SUPPLY VALVE WATER PRESSURE COMMING INTO THE UNIT,AND REFRIG SELENOID VALVE,IF THE PRESSURE IS OK ,REPLACED THE ICE MAKER,,ALSO CHECK FILTER AND WATER TUBE FOR WATER LEAKS..
Jul 05, 2011 | Sub-Zero 650 / O Bottom Freezer...
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
If my ice cubes are incomplete from my manitowoc ice machine and I sometimes here them falling early and hitting the bin before it dumps. Is the ice thickness set too thin or too thick? Thanks for your...
The ice thickness is too thin...
turn the screw on the ice sensor IN or clockwise about 1/8 turn at a time till you get the right thickness...give it a couple of dumps before making another adjustment after doing the first one...be careful as the sensor is very sensitive and can be knocked out of wack very easily...
heatman101
Sep 28, 2010 | Refrigerators
Ice maker don't make ice
Pour about 2/3 cup of water into the ice maker . If it dumps the cubes but doesn't refill with water , replace the water inlet valve , behind refrig , where the water line connects to on the refrig .
If it does not dump the cubes , and the cubes stay in the ice maker , replace the icemaker .
Oct 13, 2009 | GE Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
