Ice dispenser stopped working, no cubes or crushed,( ice making is working) when arm pushed nothing happens, no noise--then water dispenser stopped working but change of filter fixed this. Temperature display for freezer and fridg does not display for a few seconds then its displayed this happens a few times a day, temperture display off by 3 or 4 degrees to what it was set at, contents of freezer/fridg seem OK.
The auger motor gear boxes may also freeze they are exposed to extreme cold temps in the past i have removed the auger motor and derosted it with a heat gun not guaranteed but worth a shot
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
correct model number entered for this fridg is psc23ngsb cc not the one that was displayed.
