Question about NAD T531
Stops after few seconds
My player when turned on works for a few seconds then stops and the powerlight starts blinking. After that i can not do anything besides unplugging. Can anyone help me? Is it a small problem?
0 characters
1 Points
Portable dvd player slows or stops
The pladder motor that spins the dvd disc is failing, or the 5volts to the motor is flutuating, usually the whole assembly is replaced and is expensive.
Jul 18, 2012 | Zenith DVP615 Portable DVD Player
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | DVD & Blu-Ray Players
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
When truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "welcome" but stops before it is finished.
when truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "wel" but stops before it is finished.
Feb 04, 2011 | Sony DVP-NS305 DVD Player
Blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
Oct 01, 2008 | Sony RDR-VX555
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Mintek MDP-1815 dose not play disc
Please supply me with all the types of equipment that you have connected together and the configuration....accordianman
Jan 13, 2008 | Mintek MDP-1815 Portable DVD Player
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Reads disc then stops and reads again, keeps repeating this process
Hi dangraham.....I'm not very confident whether this will remedy your particular issue, however, please click on the URL below for the information....good luck my friend
Nov 10, 2006 | Cyberhome CH-LDV 700B Portable DVD Player
NAD T531 Logo
50 people viewed this question
Top NAD DVD & Blu-Ray Players Experts
Raj Patel
Are you a NAD DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
