Question about Dryers
Hunter 28684 no light
Lights won't work
4 Suggested Answers
ynogami21
  • 670 Answers
SOURCE: My Hunter Remote FCC IN2TX01
hi there,
Maybe you can try doing these steps:
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
If all else fails:
contact hunter and see if a replacement remote is available:
here's the website:
http://www.huntershoponline.com/cc_contactus.asp
here's the phone number and office hours:
1-800-893-9330 Monday - Friday
8am - 8pm ES
Posted on Jun 12, 2011
  • 10 Answers
SOURCE: hunter fan light switch won't turn off light
by looking at the sw. it looks like u can only put it to a low dim and not off and the button at the bottom is all off including the fan if this is correct u should be able to change to a different kind of fan sw. combo or even a remote style that comes with a receiver ,also your fan should have three wires at the box a light wire "blue" a fan wire "black" and a neutral "white" oh and a ground "green" in order to switch these separate u need those 3 wires at the sw. also . but with a remote u only need the hot and neutral it hooks up in the box or canopy of the fan to the receiver all wires are marked for easy installation turn power off to be safe u can install a regular sw. to over ride the remote and turn power off at the fan .......its alot i know but hit me up if u need more help.
Mercedes Parts
Posted on May 25, 2012
  • 6 Answers
SOURCE: Hunter 5 min fan lights quit working. Can I just
That's perfectly fine.
Posted on Aug 14, 2012
Hunter ceiling fan. Remote control. Lights work, fan won't. Batteries in remote new.
If the fan came with a remote you probably need a new receiver. You can order at 1-888-830-1326. Need model #
Jul 07, 2013 | Dryers
The light works but the fan won't work
Was it an add-on light? If so, pull the light switch once and try the remote again. If not, you probably need a new receiver.
Mar 24, 2013 | Hunter 52" Ceiling Fan With Light And...
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Hunter fan light switch won't turn off light
Mercedes Parts
May 25, 2012 | Hunter Ceiling Fan Light Switch Control
I have a Hunter ceiling fan Model 23262-530 which has a minature light fixture base. I need more light. Is there a standard base with higher wattage lights that I can put in this fan Thanks, bill...
Bill, Hunter makes many different light kits that will fit just about all of their fans. You can find them at home centers like Lowe's and Home Depot. Also, I believe that Harbor Breeze Light Kits are interchangeable with the Hunter Light kits. You'll find those there, too.
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | Hunter Heating & Cooling
Dryers Logo
Top Dryers Experts
