Question about Grilling
Frigidaire fdr30 low flame on burner
SOURCE: flame low on grill however the flame is high on burner
Had the same problem. Belive it or not i basically follow the turn on instructions. Disconnet the regulator, let it stand for five minutes, the reconnect and turn it on 1/4 and turn the burner that is at the end of the line. (in my case the is the first one on the left).
Posted on Feb 22, 2009
  • 10 Answers
SOURCE: One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Posted on Mar 29, 2009
  • 199 Answers
SOURCE: yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Posted on Jun 20, 2009
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: low flame when all four burners are on
There is nothing wrong with your grill. This is a common problem caused by turning off the tank before turning off your bbq. This bleeds the gas line to the regulator. The regulator senses it to be a leak & shuts down.
To Fix make sure all knobs on the grill & the tank are turned off. Unscrew the regulator from the take for 60 sec then reconnect. This will release the pressure in the regulator & it will reset.
You should be good to go
Posted on Aug 12, 2009
Why is cooktop burner flame uneven?
Check for clogged burner orifices.
Mar 22, 2016 | Frigidaire Kitchen Ranges
High flame on burner
the adustment screw should be at the valve.
Jun 14, 2013 | Frigidaire FGFB75D Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Smell gas when dryer running. no smell when dryer stopps.
your not getting enough air to gas mixture to burn the gas completely,you will see an orangish/yellowish flame if the air mix is too low,access the burner tube and adjust the air throttle on the tube entry end till its a clean blue flame
Jun 18, 2010 | Frigidaire FAQG7077K Gas Dryer
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Yellow flame on the rear of my burner
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
It take a long time for my gas range to pre-heat
the oven flame seems to be to low, that flame most be at least 2 inches long. not counting the sides of flame from one side of the burner to the other, but from where the flame begins at the metal of the burner.
Dec 11, 2008 | Frigidaire Kitchen Ranges
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Grilling Logo
37 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
