Question about Sharp Multi-System Mini Component System Shelf System
Error message on Sharp CD-DK890
I am getting an error message on my unit - "ER - CD01" The unit will no longer play CD's. I have tried using a lens cleaner to no avail. The light for disk 2 blinks on and off, but there is not a disk on that tray. This first happened after I used the random play feature and it seemed to hang up on one disk. Now it does nothing. Any help would be appreciated.
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
SOURCE: Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Posted on Oct 27, 2009
Beelz
  • 666 Answers
SOURCE: THE SYSTEM SHOWS ME ER-CD01
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Posted on Apr 23, 2010
SOURCE: The 3-Disc Rotary Changer will not eject. Error ER-CD11 appears.
notice sharp 3 disc rotary changer en français; svp
Posted on Nov 26, 2010
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
THE SYSTEM SHOWS ME ER-CD01 AND ALSO THE PLAYER WONT PLAY THE CD, IT DOESN'T EVEN READ THE CD
hope this helps
Robb
Apr 23, 2010 | Sharp CD-MPX850 Shelf System
Put a CD in and get message that says ER (Error?)...every CD that goes in spins, but does not play.
could be one of 2 things
use a cd lens cleaner to clean the laser lens .
or could be warped or damaged cds and player wont play them
also if they are burnt cd the player may be to old to read them.
Apr 26, 2009 | Audio Players & Recorders
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
i had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Dec 05, 2008 | Audio Players & Recorders
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Error message
Check and see if there is a fuse on the back of the unit if so check it to make sure that it is not blown. Also make sure that it is at least a 25 - 30amp fuse. If that is not it the make sure you have the power wires hooked up right. See a Er-05 message means that the power that that unit needs is not there. So it will not read all cd's. It takes more power to read a burner than a normal cd. Hopefully this helps
Dec 11, 2007 | Kenwood KDC-MP228 CD Player
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Sharp Multi-System Mini Component System Shelf System Logo
96 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
