Question about Whirlpool LSB6200KQ Top Load Washer
Samsung fuzzy wasing machine WA75N6
Today when i switched my samsung washing machine on,the fuzzy,wash,rinse,spin indicators are on, but the machine is stuck.pls suggest a solution...
  • 4 more comments
  • Anonymous Nov 20, 2007
    My samsung washing machine indicators fuzzy, wash, rinse and spin indicators are on all at the same time. The machine is not working. The Samsung mechanic says the control board has to be replaced. I wonder - can't it be repaired? Does anyone know more about this?
    janice
  • Anonymous Jul 29, 2008
    ALL BULBS ARE ON . CAN ANY BODY HELP ME ON THIS.
  • rgbarnes69 Aug 17, 2008
    an error message E1 shows on the screen
  • thomthom Feb 11, 2009
    All lights on samsung is on, nothing working, no reset button also on this unit.
    Very bad manual also for solving problems!
  • Anonymous Mar 17, 2014
    Stuck on rinse
  • Anonymous Mar 30, 2014
    My washing machine flooded twice in past few months and today isn't spinning the clothes dry. Sounds like it's jammed.
Washing mechine does not rins and spine
Posted on Sep 01, 2008
Sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Posted on Jul 15, 2008
Samsung Fuzzy Logic Washing Machine will not rinse and is showing an OE sign . What is problem and how do i fix it
The OE code indicates an Overflow Error. Too much powder or liquid detergent may have been added. If you turn off power, wait 30 seconds, and turn on power, the pump should turn on to drain the machine. If this routine doesn't work it may be necessary to call for service.
Nov 27, 2016 | Samsung Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Give me information about Samsung washing machine wA75N6
http://www.nodevice.com/user_manual/samsung/washing_machine/wa75n6.html#
Aug 30, 2014 | Washing Machines
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
After wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | Washing Machines
Smeg s750 washing machine -how to rinse only?
Advance the timer to rinse/spin part of cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool LSB6200KQ Top Load Washer Logo
1,852 people viewed this question
Sal De
Marvin
Marvin
jimorris77
