Question about HP Photosmart Premium C309g multifunction InkJet Printer
Get paper mismatch error when trying to avery label 8165
SOURCE: Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Posted on May 04, 2009
SOURCE: Print Envelopes with hp c309a "Paper Mismatch" error
Even though the icon on the printer shows the envelopes entering the printer narrow side first, you have to set the printer up for, and feed the envelopes through, wide side first.
Posted on Dec 19, 2009
passionat423
  • 253 Answers
SOURCE: "paper Mismatch" error when trying
GOTO PRINTER PROPERTIES
CHANGE THE PAPER SIZE & TYPE.
Posted on Feb 07, 2011
SOURCE: I can't print my Avery
Try this: When printing, change your ink quality to "Draft". Good luck!
Posted on Feb 18, 2011
  • 956 Answers
SOURCE: When I print avery label
You have to setup printer details, not to sure of programme, if word try looking under mailings/envelopes. There you have the choice to alter the details of the item you wish to use as a template. Good luck.
Peter.
Posted on Mar 24, 2011
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
Printing avery labels
You need to check the driver settings inthe printer properties and make sure that you are selecting labels as the paper stock. Often times this will adjust the fusing temperature so the toner is melted thoroughly on the label. You may also check the toner..some compatible brand toners do not do well on Avery labels.
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
I can't print my Avery labels bc my printer says there is a paper mismatch
Feb 06, 2011 | HP Office Equipment & Supplies
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
I'm trying to print on 5.5'' x 8.5'' cardstock on my hp c4580 printer but it keeps stating paper size mismatch... any suggestions?
Go into your "printer properties" and select "page layout" there you'll see all the size options.Thanks, Dana P.S. You may also try using the sizecode that is prited on the card wrapping for example; Avery 3757, Avery 1270 etc. etc. Thanks Dana
Jan 06, 2010 | HP Photosmart C4580 All-in-One - InkJet...
LABEL PAPER
8.5 X 11 PAPER WITH 1.25 X 4 LABELS IN 2 ROWS
NORMALLY WHEN YOU GO TO LABEL PAPER IN THE PRINTER PROPERTIES IT GIVES YOU SEVERAL OPTIONS ON WHAT LABEL PAPER CONFIGURATION CLOSELY MATCHES WHAT IM USING. I DONT HAVE ANY OPTIONS AT ALL
Sep 03, 2008 | HP LaserJet 1000 Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
HP Photosmart Premium C309g multifunction InkJet Printer Logo
Seeker5211
Seeker5211
