Question about Huffy Regatta 26" Womens Bike, Sea Foam
Adjust handlebar height - Huffy Regatta 26" Womens Bike, Sea Foam
2 Suggested Answers
  • 484 Answers
SOURCE: The handlebar keeps slipping down and will not
There is a bolt with either an allen head or a hex head that pinches the bar on the stem. Tighten this bolt and it should stay put.
i hope this helps
-matthew
Posted on Nov 15, 2009
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
How do you raise the handlebars?
That depends on what sort of headset you have. the most common these days is a straight fork with a clamping stem that retains the fork, keeps the steering bearings properly loaded and that the handlebars attach to. You can get some that allow you to change the height, but if yours if fixed then likely the only thing you can do without parts is to flip the quill over. Depending on the stem you have and how it is currently mounted this might not gain you any height. As you can see from the picture, in this case flipping the stem over will lower the handlebars
25815371-zv4th55h254xa4tiaa1soakf-2-2.jpg An adjustable unit allows you to change the height of handlebars to suit your size.
Aug 09, 2015 | Gary Fisher Napa
How can i raise handle bars on my diamond insight
Today's bike stems have minimal adjustment height, if any. Look at your stem to see if it has spacers. These spacers can be moved up and down the stem. For more adjustments, you will have to buy a new stem. Here is a good place to read up on
How to adjust handlebar height BikeRadar
Sep 26, 2014 | Cycling
How do you raise the handlebars on a next bike
Loosen the center post bolt and wiggle the handlebar back and forth while pulling up. There isn't much height adjustment. You can get a longer center post from a bike shop if you can't get a comfortable adjustment.
Sep 24, 2014 | Cycling
How to adjust the handlebars on a bike
To adjust the handlebar position on your Raleigh, loosen the nut on the bottom of the stem extension. Use a 13mm or 14mm wrench, whichever fits. Do not use pliers or Vicegrips! It is upside down, so be careful to turn it counter-clockwise while looking at it from the bottom. To change the handlebar height, you need to loosen the bolt on top of the vertical part of the stem. You may need to tap it with a small hammer to break it loose after it is loosened about 1/4 inch. Now you can adjust the handlebar height, being careful not to exceed the maximum height engraved on the stem. You should also carefully align the bars with the front wheel before tightening the bolt. If you do not understand the terms used here, you should take the bike to a bicycle repair shop.
Feb 26, 2013 | Raleigh Krush 16 Girls Bike 2012 - bikes
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
I want to adjust my handlebars from mountain biking position to street riding. How do I do that?
One man's road position is another man's mountain. Which DIRECTION do you wish to go with them?
Depending on its current orientation and deviation from 90 degrees (known as rise) the stem could simply be flipped to change the height.
Read this...
http://www.sheldonbrown.com/handsup.html
Google "how to change handlebar height" for videos.
Jun 27, 2011 | GT Timberline LTD
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Huffy Regatta 26" Womens Bike, Sea Foam Logo
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
