Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
Turn on the TV.
Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
Verify by pressing the SEL button. This should turn the TV on and off.
Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method
Use this method if the three-digit code method does not successfully program your remote control:
Turn on the TV.
Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
Hold down CH+ and release it as soon as the TV powers off.
Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
Press CH+ one at a time until the television shuts off.
Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Which is this a jmb or a job TV, here is a link to the code lists available online , it is most complete USA code list I can find. Remote Control Programming Codes
Microsoft network & wireless adapters retune jmb tv related questions and answers. Ask your Microsoft questions. Get free help from network and wireless ...
Hi , silly question but I have a jmb tv 32 inch code Jt0132003B/01 but can't find the power button on the tv !?! I looked all over the tv but doesn't seem to have one ??? I don't want to leave it on stand by so my only option is to turn off at wall but that turns off My talk talk and DVD player too , any know where is it !?!
here is want I have found so far, hope they work for us. 10030 10090 10029 10030 10019 10093 11523 11178 10178, this is the same problem I am having Don't know if they will work for. if you have any you have found please posed them on this sight.
I didnt have enough information about your remote to make sure I got you the correct codes. It appears there are about 3 different remotes they use. The link below takes you to there site. Click on the remote that looks like yours and follow the instruction to get your code.. seemed pretty straight forward when I tried it.. Good luck..
