Question about Cub Cadet Super Lt-1550 Riding Mower
Pto problems PTO will only stay engaged if I use the reverse safety mode. In normal mowing mode it will disengage after only a few feet of movement.
  • 7 Answers
SOURCE: The pto quits working after a few minutes of
Check the drive belt , it is probably worn and polished, it will grip a little when cool but will slip as soon as it gets hot.
Posted on Aug 22, 2010
heatman101
  • 43501 Answers
SOURCE: PTO problem on a model
I would be looking at the ignition switch....but before replacing it I would be looking for a friend with an electrical meter and checking the wiring for power coming out of the switch to the cluthch, this way you can narrow it down positively before buying parts.
heatman101
Posted on Jun 18, 2011
  • 6468 Answers
SOURCE: PTO will not engage
the safety system wouldn't know if the clutch its self had failed see if your getting power to the clutch with some one on the seat or a jumper on that switch the clutch could have failed also look at the wires going to the clutch they break to
Posted on May 01, 2012
SOURCE: Hi...I have a 2005 Cub Cadet 2042. With the switch
How can I bypass revers shutoff switch on a lt1042 so blades don't shut off when I back up
Posted on May 04, 2012
  • 6468 Answers
SOURCE: PTO will not engage onLt 1046
check the safety switches start with the one on the seat
Posted on Jun 06, 2012
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
PTO stay engaged on allison transmission md3060/ PTO chelsea 277
wires to the pto solenoid incorrect and not wired properly through the switch
did you put the correct shims under the flange of the pto mount as it it is incorrect distance , the pto teeth will say jammed in the transmission gear teeth
suggest that you take it to a shop that fits pto and have the installation checked before you damage the transmission
Mar 12, 2013 | Garden
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Super Lt-1550 Riding Mower Logo
90 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
