Question about John Deere Starter Tractor 8100 8200 8300 8400 ()
Where do you drain the oil on a John Deere 8335R tractor?
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 61 Answers
SOURCE: My John Deere 2010 tractors lift does not work.
Here is a link to the John Deere web site for the manuals.
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=2010&submit=Search&language=english
Also,
The hydraulics on a 2010 are part of the transmission oil system. There is a bolt looking plug on the right side of the transmission, about half way up, about where your feet rest when your foot is not on the brake. Fill up the transmission until the oil is level with the top of the hole and is about to run out. Using HyGuard hydraulic/transmission oil or one that meets the same spec for the 2010.
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Posted on Sep 10, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
Where is the oil drain plug on the sx75 John Deere riding mower
It is not a plug, it is a drain petcock (nozzle) you will need about 2 feet of hose that you slip over the nozzle, then turn the Knurled Knob (brass ?) behind the drivers side rear tire (maybe the passengers side rear tire) It will probably have oil on it and may not be that visible, it is right at the bottom of the engine. Not that fun...but it is easy.
Apr 16, 2015 | John Deere Garden
Whats the right type oil to use in john deere 1070 tractor
every time i tried synthetic oil in a lawn mower it started to leak oil but i do use it in all my cars
Apr 20, 2012 | John Deere Garden
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Where is the oil drain plug on my John Deere LX277garden tractor?
look on the same side as the muffler there should be a small pipe with a threaded cap near the base of the engine. remove the cap and drain the oil into a pan..good luck
Apr 10, 2010 | Garden
Need to locate the oil pressure sending unit on a John Deere 1010 Gasoline tractor
looking at engine on oil filter side--the sender is on the left side of oil filter and to the right of dipstick in between both
Mar 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need to change tranny oil in 550 deere is there a drain?
If it is four wheel drive then take the drain plug out of the fwd drop box.If not fwd the there is a plug in the lower part of the differential/rockshaft housing that you can remove.
Nov 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I just purchased a 2440 john deere tractor it was outside for some time so there was H2O in the hydraulic fluid. I changed fluid but I get very little movement from the tractor when I release the clutch. I...
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Starter  Tractor 8100 8200 8300 8400 () Logo
178 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
