Question about Emerson MW8779W Microwave Oven
ARG! Ok I have a model MW8780SB. Cant find it any where so I picked the closest model #. Neways...The key pad works and everything,however,when I put any thing on cook nothing works. I think that maybe there is a door issue or something cause it only wont work for the cook functions(popcorn button,start button for cooking,etc..) Help me! What do I do!
  • Emerson Master
  • 9,156 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Many Emerson microwave manuals are available here: http://www.emersonradio.com/owners/MWO%20manual/
Posted on Oct 22, 2007
SOURCE:
Were do I find a replacment light bulb for my Emerson microwave. Model# MW8780SB
Emerson Microwave Parts Here is the manufacturer's number for your part 26QBP0930 The website provided carries the part.
Dec 03, 2014 | Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Buttons don't work
Hello there:
This is normally caused by a faulty touch pad that is failing These touch pads are replaceable but they can cost about 60 to 100 dollars depending on the exact make and model ok
I hope this is very helpful for you
Best regards Michael
Dec 11, 2009 | Microwave Ovens
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
My microwave emerson MW8780SB doesnt heat everything else work
what is wrong is that your megatron went bad, is this a counter top unit or is it a built in? if it is a built in i would suggest fixing it, and if it is a really expensive counter top i would fix it, but the part cost about $80 to $100. so it would be up to you. if you want to go for the fix write me back and i will walk you through it.
Dec 22, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Turn off Demo Mode on goldstar Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
Otherwise, try holding CLEAR for 3 seconds, then try each pad for 3 seconds.
Sep 07, 2008 | Goldstar MV-1615 Microwave Oven
Emerson MW8779W Microwave Oven Logo
169 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
