Marantz PDM 510 Dual Cassette Deck
Manual
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Posted on May 05, 2008
  • 54 Answers
SOURCE: Cassette door won't open
IF it is a deck with " soft touch " controls, that is, you arent using the old press hard down " piano key" style, but NOT a pure touch switch activation, then chances are either the drive belt has slipped, the belt broke, or the motor died. If this is the case ( soft touch = yes ), then unplug the unit, pop the cover off. You should be able to see the mechanism. When you view the mechanism from the front ( the side you normally see when using the deck ), the shiny little silver post that pulls the tape through during normal play will turn counter colckwise ( the shiny post runs against a rubber wheel ( the pinch roller )). What you should try is , with the unit unplugged and the cover off, if you can get your fingers to the deck in question, find the flywheel, should be a larger disk with a belt around it. Carefully spin the flywheel with your finger so that it turns counter clockwise, if you were looking from the front of the unit. This should cycle the deck through its cycle until you hear a click. Try to open the door. If the door doesnt open, press the stop button WHILE turning the flywheel again. This should drop the head assy and disengage the door lock mechanism. Remember, make sure the deck is unplugged, and BE GENTLE. you may feel a little resistance as you turn the flywheel. A little is OK, just be careful. If the flywheel comes to a hard stop when you are turning it, then something is jammed and you need to take it to a repair shop. Good luck...Rob. In the future, please specify a make and model so we can better help you . Thanks !!!
Posted on May 09, 2008
caroldon
  • 17129 Answers
SOURCE: How to replace drive belts on Technics dual
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
Posted on Jul 20, 2010
skywavebe
  • 1258 Answers
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
Need a service manual for dual-cassette deck.
Tru Hi Fi Engine or owners-manuals.com and if that does not pan out then stereomanuals.com where fine paper versions are.
Jan 08, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Where can i find a sony dual cassette deck tc-w490 manual
I can give you this link. You can download the service manual of this Sony. I hope it will be usable for you.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
Feb 15, 2012 | Sony CASSETTE DECK Single Dual Cassette...
Replacement motor
You can identify rotation direction of the motor and order one from this site
http://www.studiosoundelectronics.com/cassette.htm
Apr 10, 2009 | Denon DRM-555 Dual Cassette Deck
HOW DO I GET A MORANTZ RECORDER DIAGRAM
if paper, photocopy it, if cassette, use a cassette dubber. if you don't have one and need one, try phoning the company, or ebay or google it. www.hifiengine.com has a buch of free manuals and other paraphanalia. you will need to sign up but it's free and they don't need much information.
Mar 18, 2009 | Marantz PMD101 PORTABLE PROFESSIONAL...
Incorrect record speed
do you have a reel to reel deck or another machine? You may also need a schematic. Make a copy of about 2 minutes of a tape on a working machine. Keep the original in the working machine. Each cassette deck needs a different size belt. Try putting different size rubber bands on it. Cassettes usually play at 1 7/8 IPS (inches per second) each speed increases or decreases by doubling or dividing by 2.
Aug 30, 2008 | Marantz PMD101 PORTABLE PROFESSIONAL...
WE475 Sony Dual cassette deck
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 26, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Dual tape deck speed
you might get in contact with mcm electronics and buy a product called re-grip...this product rejuvinates the rubber,, i suspect that your problem is not so much a speed problem but one of slippage,,,,dress all belts and rollers with this product, wipe the excess with a as many q-tips as necessary and allow to cure for a few hours, re-assemble and enjoy your unit again,,,,this should solve your problem,,good luck
Jul 12, 2007 | Marantz PMD510 Single Cassette Deck
67 people viewed this question
 Grubhead
Grubhead
