Question about Dryers
Amana lea30aw schematic
Going from 3 wire to 4 wire. old cord had no colors
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
mikedurland
  • 481 Answers
SOURCE: How do I replace an
  • white wire (neutral) goes in the middle, between the two hot wires
  • green wire goes to the case, should be a green screw or bolt to connect to
  • black and red wires are hot (110v each) one on each side of the neutral.
let me know if you get stuck name brand would help Mike
Posted on Jul 27, 2008
Healeyman
  • 1198 Answers
SOURCE: Electrical wiring
The green is the safety ground, it goes to a contact that is directly connected to the body of the dryer. A dryer cord is usually a flat thing with the wires that have lugs crimped on them. Usually the power wires are black, and the neutral wire is white. It's usually difficult to put it on wrong, so if it goes easy, it's probably right.
Posted on Apr 27, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
canbruce75
  • 1776 Answers
SOURCE: changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Oct 07, 2009
On the amana LEA30aw which wires go where on the heating element?
There is usually a schematic pasted to the inside service area unless it fell out. Read it & start tracing wires. The power to the element should pass through a fuse, a thermistor(cycles power on and off relative to heat and a safety switch that kills power if it gets too hot. Don't take short cuts.
May 14, 2015 | Amana Dryers
What year was the amana lea30aw serial number 9805282218 age?
I've seen posts in 2007 and people said same model was 10 years old then. If that is the case it would be around 17 years old.
Sep 21, 2014 | Amana Dryers
Changing power cord from 3 wire connection to 4 wire connection
Hi jdebesch
Go to the following webpage and the pictures will show you how to convert you or 3 wire to a 4 wire connection.
I believe this is what your looking for
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Nov 25, 2012 | Hotpoint Dryers
I need to know what is the correct wireing for a amana dryer element model LEA30AW
There are two wires that run into the element. You cant mess it up if you have the right two wires. What wires do you have and the colors. Can they reach the element connectors. How many do you have?
Jul 27, 2011 | Dryers
Changing out 220 cord
Here is a tip that I wrote that will help you to figure out that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Jul 03, 2010 | Amana NED7200TW Electric Dryer
Changing dryer plug
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
