Question about Garden
I have a Huskee front-tine tiller, 16 inch, 139 cc- the motor runs but it is locked up.
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
  • 57 Answers
SOURCE: Tines won't turn
Possible broken key where crankshaft meets gearbox.
Posted on May 15, 2009
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
How do I change the oil on powermate front tine tiller?
If you mean engine oil, place unit in big drain pan, remove plug at bottom edge of engine crankcase, drain, replace plug, fill with fresh oil.
Sep 30, 2014 | Powermate 21 in. 173 cc Front Tine...
I have a huskee garden tiller that won't till. It will go forward and reverse but will not till. I'm sure it has to do with the gears but can't find any parts manuals or information on the gear box. the...
I have experienced the same problem. Mine has set unused for a couple of years. I rebuilt the carb and got it running again, only to find the tiller/tine drive is locked up. I plan to disassemble the housing this weekend. When I find out what the issue is, I will post it for you.
Dec 15, 2010 | Mtd Garden
Mtd rear tines tiller won't engage tines. F and R
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Rear tine will not turn mod 21b-403-13144-0366-6 huskee
Could be the belt if it has one. If not then your problem could be as simple as a pin broken in the tine shaft. There is also a pin in a gear in the gear box also, This will require shop work.
good luck.
Oct 03, 2009 | Garden
Tines won't turn
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
