I need to replace the old microwave with a microwave with the same specs - same with and height what is available ?
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
SOURCE: need to replace outside door frame on ge spacemaker xl microwave
Here a few site can help you:
http://www.partselect.com/
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: GE JVM 1330 WW 002 Microwave
900 Watts. Here's a link to the manual:
http://genet.geappliances.com/DocSearch/pdf/49-40092.PDF
SOURCE: Over The Range Microwave new models too tall need under 15 in hig
cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
SOURCE: I have a GE Profile Spacemaker XL Sensor Mod # JVM
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Testimonial: "Although I received this solution after I had called in a technician and paid $100, your instructions were right on and exactly what he did. Doug"
