Question about Maytag Washing Machines
Maytag model mhwe900vj00
F35 error
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
F35 on maytag 5000 series front loader.
A F35 error indicates the Central Control Unit has detected a malfunction of the analog pressure sensor.
Oct 11, 2014 | Maytag Washing Machines
Replace pressure switch
The F35 error is for a suds problem, wrong kind of detergent or too much. If this does not fix it, replace pressure switch. It is located on the rh side, at the rear. Remove the top panel by removing 3 1/4 inch screws or t20 torxs at the back of the panel. After you remove the screws the panel should slide back. It is a brown and black switch with 1 connector and a black rubber hose at the bottom.
Sep 02, 2014 | Maytag Washing Machines
Error code f35
Too much detergent or wrong kind of detergent. If you use non HE detergent this will happen. You can remove the excess suds by running a cleaning cycle and adding cooking oil. The detergent will attatch itself to the oil and remove all soap residue, add an extra rinse to the cycle. Also run it empty.
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
I am getting a Sud code and then an F35 error on my Maytag frontload washing machine. I have unplugged it...to reset and sometimes it works. Other times it doesn't. How can I fix it?
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.
Jul 31, 2011 | Maytag Washing Machines
My washer keeps getting and F35 error code and stopping
Hope this helps.. The "F35" error code is indicating a problem with the analog pressure sensorswitch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on theleft hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Jun 20, 2011 | Maytag Washing Machines
Kenmore elite he5 is displaying code f35...can't find find what this code stands for
Welcome to FixYa.
The F35 error code on most not all ...Whirlpool built front load washers ( this includes Kenmore, Amana, Maytag, Speed Queen and of course Whirlpool...but will vary slightly based on model number ) indicates the control has detected an analog pressure sensor error...please post the complete model number inside the door opening.
Whether the sensor is faulty or not remains to be seen, here's what to check first.
**Unplug the washer from the wall before servicing...safety first**
This error "F35", can be caused by the air pressure tube between the bottom of the washer tub and the analog pressure sensor, examine by removing the top and back panels and inspect the hose and dome, i.e.
If you find a cut/torn hose or loose connection in tube, then this is the likely cause the error. If it however appears okay, then you will likely need to replace the analog pressure sensor, i.e.
As I alluded to though, make sure the hose is clear and not cut and the air-dome at the tub isn't plugged and if not you'll have to replace the switch.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Regards,
Macmarkus :)
Mar 11, 2011 | Washing Machines
F70 mhwe900vj00
What is f70? is that an error code? there is no f70. there is an f07 code.
http://www.repairclinic.com/0078.asp
there it will tell you what f07 means and what to check
but if i am way off tell me what exactly you want to know thanks
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model: wfw9500tw01 f35 error
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error F35 ON KONICA COPIER
Yes you can, but need to know what model you have. different service mode for different models?
Oct 07, 2008 | Office Equipment & Supplies
Washing Machines Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
