Question about GE Energy Star WCVH6260F Front Load Washer
GE Front Load Washing Machine
When I put the liquid soap in the drawer at the top of the machine it doesn't wait for me to close the door and start the machine. The soap is running out on the seal and all over the door. I have checked the soap dispenser and made sure the plastic piece is all the way down and inserted the right way. I can't figure out what is wrong with it. I have owned this machine for about a month now and this problem just started happening a couple days ago. Please Help!!! Kim Soko
  • Anonymous Mar 25, 2014
    After wash complete soap still in dispenser
  • 641 Answers
It sound like a lid switch problem. Since your washer is still under warranty you should contact GE service center for their assistance. Good luck!
Posted on Aug 07, 2007
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service
Jan 28, 2016 | GE Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
    I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
    Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
    Can you use granular soap and where to apply it? we have a frigidaire washer with a drawer to put liquid soap in.
    On our washer there is a little slider in that drawer that allows the opening into the washer to open wider for solid laundry soap. Maybe that's the case in yours. If not then you might be confined to using HE liquid soap.
    Mar 05, 2011 | Frigidaire ATF6000ES Front Load Washer
    I have a Samsung WF316LAS/XAA Washing Machine, has worked great for 4 years. Just started pouring water out of the soap dispenser drawer when in a washing cycle. Any advise
    take off the top and check the hose that leads to the tub may be plugged . May have to take the boot(door)seal off front under door to access lower end.
    Nov 20, 2010 | Samsung WF306BHW High Efficiency Front...
    When in wash it dosent remove all soap powder from clothes
    I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
    May 15, 2010 | Zanussi ZJ1217 Front Load Washer
    GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
    Hello there:
    Here is a few tips that might help you out
    Hope that they are very helpful for you
    Best regards Mike
    Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
    Soap dispenser leaks
    The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
    Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
    Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
    Tips for finding a leak on a washing machine
    • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
    • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
    • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
    • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
    • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
    Nov 13, 2009 | GE WDSR2080D Top Load Washer
    What holes
    Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
    Jul 27, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Where to put the detergent and liquod softener in newHaier washer
    Detergent goes in the drum with the clothing, fabric softener in the middle of the agitator, the drawer is for delayed start if using soap powder
    Apr 04, 2017 | Haier XQJ50-31 Top Load Washer
    Washing machine problem
    at the back of the conditioner compartment there is a syphon. check the tube of the syphon is clear. put on rinse and at the point the conditioner should be taken, open the drawer and check that there is a jet of water into the conditioner area. if not, there are some holes in the roof of the top of the box. these may be blocked. clear with a hairpin or similiar
    Apr 22, 2007 | GE WSXH208A Front Load Washer
    GE Energy Star WCVH6260F Front Load Washer Logo
    50 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
