Question about Maytag MDBH975AWS Stainless Steel Dishwasher
Service number kuds301xbl2
Will not run. Lights work so there is power. Started when my wife leaned against the door to reach an up cabinet-she is vertically challenged, when the washer was not running and engaged the Cancel/drain pad. Started the Cancel/drain cycle and she opened the door as there was nothing to drain to stop the cycle. Washer has not run since. This is what happens-Door open; shut door completely; push Start/resume pad once;Normal Wash light lights;push Start/Resume pad second time;Start light comes on for one Beep and then goes dark but the intermittent Beep continues for 15 Beeps and then all lights and Beeps stop. No wash or anything. Any help?
  • 30 Answers
SOURCE: maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Posted on Aug 15, 2007
watugot
  • 290 Answers
SOURCE: washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Posted on Nov 05, 2008
sdmc73
  • 121 Answers
SOURCE: Maytag Neptune MLG2000AW Frontland Neither Washing nor Spinning
sounds like the moter speed control
Posted on Nov 29, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
How do i replace belt
On this model in order to replace the belt first disconnect power to the dryer. Looking at the front of the unit in the seam between the front panel and the dryer top, use a putty knife to press in & release the spring clips in the right and left sides of this seam to release the top panel. Lift the panel & rest it against the wall. Reach in & remove the 2 screws holding the front panel to the side panels. Once you have removed the screws, lift the front panel up slightly to remove the complete front panel from the stationary clips at the bottom of the dryer. Be careful with the wires going to the door switch. Either remove them from the switch or simply lean the front panel against the right side of the cabinet. Next, lift the drum and slide the new belt around the drum to the mark made by the previous belt on the drum. Be sure the ribs are facing down. Part number for the drive belt is 31531589 which over the years crossed to 341241. On your knees, reach back by the motor and idler assembly and lift the idler pulley tension arm to route the belt allowing the idler to take up the slack in the drive belt. Reassemble and dryer some clothing.
Mar 24, 2012 | Maytag PYE2300AY Electric Dryer
The door remains locked
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Some
Whirlpool-made Front Loading such as the Kenmore Elite use another type of door lock and switch assembly but still with the release tab and can be accessed through the washer top. Remove the screws attaching the top panel to the rear of the machine then pull the panel rearward and off the cabinet. Pull the release tab until a click is heard then open the door.
Dec 24, 2010 | Kenmore HE2 Plus Front Load Washer
Cannot open the door to the Duet washer
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Replacing the Door Lock and Switch Assembly
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door won't open fault code dl comes on when you try to use the machine how can i open the washer machine door.
Disconnect power then remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door won't open
Whirlpool Front Loading washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer before accessing it.
Aug 23, 2010 | Whirlpool Washing Machines
How do I unlock the door
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access the screws more easily.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How can I get the door open, when stopped in middle of cycle, And I have unplugged it from the power source, then plugged it back in?
Jun 09, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Unable to open door
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front door is locked and I cannot restart machine. Indicator light says "f d/l". How do I unlock the door?
Disconnect the machine from the outlet. Prop up the lower front edge of the machine with a block of wood or cushion the top rear edge with cloth and lean it against the wall. Remove the three screws securing the lower toe panel to the cabinet and pull it down then out.
Reach up and locate the bottom of the door latch assembly along the inside of the front panel. Gently pull down the manual door unlocking tab until a click is heard. Open the door when the click is heard.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
41 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
