Question about LG Televison & Video
Screen only display half of screen LG 42LF20FR
4 Suggested Answers
  • 208 Answers
SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Posted on Feb 03, 2008
gsalmen
  • 77 Answers
SOURCE: LG DU50px10/10c ; left half of the screen displays
the screen or the x or y screen supplys have failed. contact a servicer
Posted on Jul 10, 2009
SOURCE: LG 50" plasma PDP50X4 only shows top half of screen, sound and top half of screen work fine....Help!
That's a relatively easy one - you have either upper or lower Y-Sustain buffer board gone bad.
if the last chip of the upper buffer has failed you may get what you get, even that this is a relatively rare type of failure.
The same would happen if the lower buffer is bad although this is again somewhat rare for a failure for those boards.
Either way you need a new buffer board and I'd start with the lower if I were you.
I assume nobody has messed up with the TV because another possible explanation would be the two buffer boards were disconnected from each other.
The best is they are neither too expensive nor hard to replace.
Hope this helps!
Oh, here's a link with something more about those boards although I am not sure it would apply to your particular case...use it as a good educational resource, but don;t expect to have the exact problem described there:
http://blog.coppelltvrepair.com/2010/10/vertical-or-horizontal-color-lines-in.html
For more help please use www.coppelltvrepair.com/diagnose ..
Posted on Oct 01, 2012
Testimonial: "Thanks for that, I'll order both boards and just replace them in one hit, cheers - your a legend."
Lg 50pc5d
If picture only one side or only top or bottom set uses two boards to drive the screen, either one of them is bad or the actual display panel itself--it is the entire screen unit where the picture is displayed.
May 25, 2012 | LG 50PC5D Television
Touch screen not working only allowing me to access one item on the front screen and the inside screen is cut in half
Hi, the problem might be from different areas, like the touch screen or from the flex of the phone.
due to the cut half display,might has affected the touch pad. You will need to replace the cut half screen to see if the screen is attached to the touch pad.
Also the phones touch screen might not be working because there might be a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
Have a nice day.
Sep 03, 2010 | LG enV Touch VX11000 Cell Phone
Screen split in half
Hello, same thing happened to my 10 day old 60ps60 and we called LG and they came out and put "pin tighteners" on the Y board. All they are are these little white plastic clips that the technician put on the connectors. It is nothing you can fix. Call LG
Sep 05, 2009 | LG 60PS60 60 in. Plasma HDTV
LG KS360 display not functioning correctly
I couldnt find a solution to this problem... If you can take it back to place you got it from and say its faulty. I did that and they replaced my phone with a new one... No problems yet ~ but I've only had it a day...
Aug 24, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Half of my touch screen on my LG Arena is no longer working, there is no reason for this. Can i re-callorbrate my screen any way?
if the other side of the screen responds correctly then it is calibrated correctly and it is a faulty screen. if not then for this model im unsure exactly how to calibrate the screen but it should be somewhere under settings and display
Aug 02, 2009 | LG KM900 Arena Cell Phone
Display problem
The best way is to change the screen.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 01, 2009 | LG Studioworks 570LS 15.1" LCD Monitor
LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Aug 31, 2008 | LG Studioworks 45 14" CRT Monitor
Televison & Video Logo
52 people viewed this question
