Question about Frigidaire GLTF2940F Front Load Washer
Gltf2940fs ERROR code E5E. Washer will turn on and tries to call for water, etc.. but nothing happens.
    New Friend:
  • 4 Answers
Washer stopped working, displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the control board, closed up the machine and it's back in business.
Posted on Jul 23, 2015
SOURCE: washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Posted on Apr 16, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
  • 401 Answers
SOURCE: starts up with lights , water turn on then off error E5E
COULD BE SEVERAL THINGS FROM A MOTOR BOARD TO A LOCK SWITCH, SOMETIMES YOU CAN UNPLUG THE WASHER FOR 1/2 HR THEN REPLUG, THIS MAY RESET THE CONTROL GOOD LUCK
Posted on Jan 15, 2010
  • 126 Answers
SOURCE: I have a Frigidaire GLTF2940FS front load washer
it pretty much has to be coming down the front, underneath the door. If your rubber boot is really dirty or has a lot of hair on it this will happen.
Posted on Nov 08, 2010
richroth
  • 9472 Answers
SOURCE: Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Posted on Nov 29, 2012
How do you fix an e5e communication error on a frigidaire washing machine?
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
What to do with err code e5e? help
Hi Friend, this is Z. Thank you for your question!
Typically error code E5E indicates that your Frigidaire washer is experiencing a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair your washer. Typically, a technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However if the wiring is good the main control board may need to be replace or if the problem is not corrected, the speed control board is possibly faulty.
Jul 10, 2014 | Frigidaire ATF6000ES Front Load Washer
Error code E5E
E5E is for the control board failure. Here is the replacement part.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Frigidaire GLTF2940ES Front Load Washer
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 15, 2012 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Starts up with lights , water turn on then off error E5E
Jan 15, 2010 | Frigidaire ATF6000ES Front Load Washer
E14 Reed switch.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Feb 16, 2008 | Kenmore 43042 Front Load Washer
Frigidiare washer not doing anything
Before replacing check the voltage to the machine. Make sure the machine is not on any extension cord.when the machine is turned on make sure the voltage doesn't drop more than a few volts.
Oct 05, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940F Front Load Washer Logo
150 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
