Lg wf t1022tp
HOW CAN I CLEAN THE LINT
  • 1294 Answers
SOURCE: Water filing
Possible your outlet hose is at floor level; this must have a certain height, the height may be marked behind the machine. The hose should reach this height (approx 30 inches) from the floor level, and then go down into your wall outlet or whatever. The outlet pump pumps this water out over the height. Check this out.
Posted on May 22, 2007
SOURCE: LG WF T1022TP Drain Problem
The problem has been traced to the water pump that does not turn on every occation that the power is applied. The pump just vibrates. Quess that it is worn out, and needs to be replaced.
Posted on Sep 13, 2008
  • 1525 Answers
SOURCE: How does the gearbox on a LG WF-T1022TP work? Mine
hello i'd check the brushes first on the motor and spin control is down to the module circuit board good luck
shaun
Posted on Aug 31, 2009
  • 713 Answers
SOURCE: My LG Washing Machine WF-T853A is putting black ru...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
Posted on May 15, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
My LG Fuzzy Logic WF-T1022TP let in more water than the level according to the weight of the bundle, sometimes even until the drum overflows. Is there something wrong with the computer?
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Jul 18, 2017 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
Please can you assist in providing a replacement part for my washing machine model # WF-T1022TP, the gearing needs to be replaced and Early bird seem to be unhelpful?
Try using buyspares.co.uk . It doesn't give you model but if you select a similar model like WFT1031TP it gives an exploded diagram to help find the part you're looking for
Feb 22, 2011 | LG WFT1071TP Top Load Washer
How does the gearbox on a LG WF-T1022TP work? Mine refuses to spin fast, and then it shows ''Spin error''.
shaun
Aug 31, 2009 | Washing Machines
LG WF-T1022TP Fuzzy Logic
hi my name is joyce
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Feb 06, 2009 | LG WFT1071TP Top Load Washer
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Sep 12, 2008 | Washing Machines
Water filing
May 22, 2007 | LG WFT1071TP Top Load Washer
Open Questions:
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
