Question about Kwikset Chelsea Handleset, Satin Nickel
Kwikset handleset diagram
Assembly diagram
3 Suggested Answers
  • 10 Answers
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
Posted on May 22, 2009
  • 101 Answers
SOURCE: How do I reassemble the latch mechanism of a kwikset 510 handle set?
http://s7d5.scene7.com/is/content/BDHHI/5048328
This might be helpful
Posted on Aug 07, 2014
Kwikset thumb plate on handleset is loose and won't work
Remove outer trim, tighten inner trim, put outer trim back. Go to Kwikset.com for full installation instructions for your model.
Dec 31, 2013 | Kwikset Locks & Locksmithing
Install a single handleset
Is this into an existing door or a new door. Is there existing cut outs where the lock set goes or is this a blank door?
Jan 21, 2013 | Kwikset Ultramax Security - Shelburne"...
How to install single cylinder handleset with lido lever
I'm not sure whether you need instructions for an entry door or an internal bedroom or closet door. So let me steer you to the online site:
Go to :
http://www.kwikset.com/Products/Categories/Door-Levers.aspx
Then "Browse by function" for the appropriate type, then choose the Lido
On the next page, you can click on any Lido finish, the instructions will be the same regardless of finish.
Once you 're on the next page, under the red "Technical Documents" heading, choose "Installation Guide".
It will take a moment to download the PDF file of the installation instructions for you to follow.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Aug 02, 2012 | Kwikset 4 Lido Lh Passage Levers Satin...
How do I change from LEFT opening to RIGHT opening for the Arlington Lido handle set single cylinder
This web page will take you to the General description of your model:
http://www.kwikset.com/Products/Details/Handlesets/802AN-LIP-L03.aspx
I suspect that this special-order lockset may not be reversible-in other words- specific to right-hand or left hand only.
I therefore urge you to contact Kwikset directly for further assistance. Click on the link found on that page for Customer Support, then "Contact Us"
Any further model information and description that you can provide will be helpful.
Jul 29, 2011 | Locks & Locksmithing
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
I need extra keys for my Kwikset handleset. Had new keys cut at 2 different stores and none of them work. The keys fit in the lock, but won't turn either way. Original key turns very smoothly.
The problem you are having has nothing to do with your lock. Modern key cutting machines are so automated that they do a very poor job in key duplication. I suggest that you find an old hardware store that has an older key machine. Or possibly, it might be cheaper to simply replace the lock set. A new Kwikset keyed entry sells for about $40.00 for a lever handle. Remember to have extra keys cut at the store when you purchase the lock...so you can check the duplicates in the store. I do this at Home Depot regularly. They have a new machine, but with the lock right there, they can manage to cut some duplicates after a few bad ones.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 24, 2009 | Locks & Locksmithing
May 21, 2009 | Kwikset Professional Door Lock...
Kwikset arlington handleset needs to be tightned
Look at the most bottom part of the hardware on the inside and see if there is a little round decrotive cover [looks like a button,dime size] and will either will pop off or try unscrewing,once of you should find a single screw which will allow you to tighten hardware or remove.
Please rate.
Mar 14, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kwikset Chelsea Handleset, Satin Nickel Logo
37 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
