Question about Philips 43PP9202 43" Rear Projection Television
43 inch phillips projection t.v
A friend of mine is giving me a 43 inch rear projection Phillips T.V. I do not have the model number yet. He said it works but that the color towards the top of the screen doesn't look right, otherwise he said it works fine. He's getting rid of it because he is a hi-tech kind of guy who now has Plasma tvs and no use for servicing this one. Its been sitting in his garage. Anyone have any ideas on what it might be? I've been told that the color wheel and the projector bulb have to be replace periodically, is that true and can a handy man do the job? Any Idea on cost? Asking a lot, trying to save any unnecessary grief. Thanks Doug
  • Doug Fresh Aug 07, 2007
    Thank you for your quick response, sounds like a winner...anyidea how much it may cost to do that job?
    Doug
  • Doug Fresh Aug 09, 2007
    Thanks MikeNJ, I will definitly ask around. I will have the set this weekend and see it for myself. I'll also have the model number. The owner said it works well and is 5 years old...We'll see how free, free really is....
  • 398 Answers
There is no bulb or color wheel in a standard projection set. The standard projection set has convergence output IC's that correct the 3 colors around the edges of the picture. If one of these IC's burns out then one color may sag toward the center at the top. The defective convergence IC will have to be replaced and the convergence circuits realigned and that should be done by a qualified tech.
Posted on Aug 07, 2007
  • Mike Longo
    Mike Longo Aug 08, 2007
    When I do a housecall for a set like yours I charge $150, but from what I read here I see other shops charging $300 to $400, which I do not really understand because the new convergence IC's cost about $10 each and a good tech can have it replaced and realigned within an hour ($400 an hour... without a medical degree???). Be sure to ask around to the shops in your area and see what they charge.
SOURCE:
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
Just curious as to how much a philips magnavox motherboard would cost for a 32 inch tv.. installation included
Need the model number of the set to even begin to answer your question since there are so many different Phillips 32 inch models and they all have different components and circuit board designs.
Jun 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
HAVE PHILLIPS 60 INCH 5 YRS OLD GREAT PICTURE NO
Hi, check for any speaker switches around rear of set that may have been accidentally switched. Could potentially have a "hotel lock mode"
which some philips sets automatically entered after a set time (namely months) which limited volume settings. Your friendly local service technician may be able to help you out with that one
Mar 19, 2010 | Philips 60P8341 60" Rear Projection...
Rear projection guns not alligned red and blue outlines on images
You will need to replace the convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305-DPTV345 convergence repair kit also works for your model. You can get the kit which also contains the CD with instructions from www.tvrepairworld.com
Dec 01, 2009 | Philips 43P8341 43" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
