Question about Black & Decker FP2500 10 Cups Food Processor
Fp2500 will not start - Black & Decker FP2500 10 Cups Food Processor
When the new processor is plugged in, the motor does not work
Denise suspect all items below not locked in to place
have you locked in the work bowl ?
have you locked in the lid ?
have you locked in mouth feed chute ?
For your protection this appliance has an interlock system. The processor will not operate unless the workbowl, cover and wide-mouth feed chute are properly locked in place.
see page 6 and 7 of user manual
http://cdn.spectrumbrands.com/~/media/SmallAppliancesUS/Black%20and%20Decker/Files/FP2500%20Use%20and%20Care%20Manual.ashx
Jan 26, 2016 | Black & Decker FP2500S 10 Cups Food...
Detailed manuel for model FP2500 10 -CUP FOOD PROCESSOR
I am having the same problem. I can't seem to figure out how to insert the shredder/grater. I want my zucchini bread now!
Aug 30, 2014 | Food Processors
Black and decker fp2500 appears to be locked and
take it back to the store you bought it and they will give a new one and your money back
Aug 29, 2013 | Cuisinart DLC-10S Pro Classic Food...
Will not turn on
First point of check if the fuse in the plug, these devices sometimes also have an internal 20mm glass fuse that may need checking.
Dec 29, 2012 | Black & Decker FP2500 10 Cups Food...
Looking for manual for black and decker FP2500B proccessor
Manuals for many Black and Decker appliances are here: http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4 . The direct link to the FP2500B is http://useandcaremanuals.com/pdf/FP2500.pdf .
I hope this helps.
Oct 09, 2011 | Food Processors
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Cuisinat ROBOT COUPE Type RC 2B Serial #R1804151981
you need to set the cover correct
it will work
Jul 04, 2008 | Food Processors
Cuisinart DLC-7E
First look for a reset button. Then check that the fuse hasn't blown.
Oct 02, 2007 | Food Processors
Black & Decker FP2500 10 Cups Food Processor Logo
67 people viewed this question
Top Black & Decker Food Processors Experts
Holly...
Holly...
Jim Thurston
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
