Question about Microwave Ovens
Samsung microwave smh8165t control panel
I am not a handyman type, but I would like to ask for instructions on how to replace the control panel on my smh8165 panel. It was flickering for a while, then just stopped working. I plan to order a control panel, but am affraid, and not sure of how to replace it, and don't want to waste the $$$.
ZJLimited
  • 17970 Answers
SOURCE: Have an old Kenmore 1000
Sound liek a problem with your hi-voltage system has gone bad. The noise you are hearing is the hi-voltage transformer. This has taken the magnetron which does the heating out.
If I dont mistake, t
he magnetron has a five year warranty on it, the rest of these parts only have a year on them. If your microwave looks and sounds normal but isn't producing any heat, you should check the internal door switches, the high voltage circuitry and the circuit board for problems. You will need a certified technician to help you make these repairs.
Hope this helps.
Posted on Jul 26, 2011
  • 6771 Answers
SOURCE: ge profile microwave jvm1870sf02 buttons don't work do i need to change the control panel frame or Bkt c/panel
You will need to change the keypad along with the control board, because they are essentially of one piece. But the part will equal, if not more than a new microwave oven.
Posted on Apr 09, 2012
plaisted01
SOURCE: my smh8165 microwave stopped working
Unplug microwave. Remove (2) flat head machine screws on the top of the microwave holding in the top front trim. My trim slid left and gently pulling was removed. The control panel has (1) screw holding it in. Remove screw, slide up and gently pulling detach from microwave. There are (5) electrical disconnects which need to be disconnected. Do not force they should come easily. Lay control panel on and old towel. Squirt both the male and female connections(in microwave control panel opening) with electrical cleaner. Carefully clean up excess. Connect the (5) quick disconnects and carfully fit back in the control panel opening. Attach screw. Place top trim in and slide right to lock. Once it is in secure the top two screws. Clean area and plug back in. Hopefully your up and running. These pieces break real easy so don't force anything.
Posted on May 26, 2012
  • 3 Answers
SOURCE: do you have a video on disassmeblying the samsung smh8165 microwave
Look on partselect.com
Posted on Aug 31, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: how do i remove a control panel on a fridgidaire microwave model # PLEB30M9ECE I don't SEE any way to get it off
    Hello lisajwalls - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Since this is a complex unit, typically this is something that you want a certified professional to install for you to prevent any exposure to radiation, safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process
    Posted on Nov 23, 2012
    What does the control panel symbols mean
    Type the following into your browser's search box Samsung RF260BEAEWW a page will appear with a list of options just chose the option you are happy with you can download the instruction manual and it shows the control panel and explains the buttons uses .
    Dec 29, 2015 | Samsung RF260BEAEWW
    OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
    Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
    Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
    SE ERROR
    I am not sure, ask the dealer
    Mar 12, 2013 | Microwave Ovens
    Samsung Microwave SMH9187 error message (?) 5E
    You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
    Aug 15, 2012 | Samsung SMH9187 Microwave Oven
    Samsung SMH9187 SE error
    Had the same problem with my microwave which is 3 years old and the warranty is expired. Call Samsung 1-800-726-7864, they have a recall and have extended the warranty for the problem. I just had my control panel replaced by tech at home for free...
    Oct 12, 2011 | Goldstar MA-1112 Microwave Oven
    I lost the instructions for my Samsung combi microwave oven Model C105. How can I get another copy
    Go to Samsung.com. Then go to products and then to your microwave. they have all the instructions for every thing they make. If still cant find it, go to contact page and 1-800 number and ask them how to get a new instruction book they should be able to direct you.
    Mar 12, 2011 | Samsung 80092 Microwave Oven
    Can i just replace the pull handle which pulled away from the door
    Hi lmnj1961,
    From my experience, that is possible, but it needs to be replaced with an exact type, especially for safety purposes. Perhaps some handyman you know may be able to help. Do not forget that if the door is not properly fitted, the switch that tells the Microwave that the door is closed may be malfunctioned. That is how a microwave can only turn on with the doors closed.
    Hope this helps,
    kamacosmic
    Feb 19, 2011 | GE JES1456 Microwave Oven
    Control panel
    For complete info & instructions, please do a search on Yahoo.com (not Google) for this: microwave circuit repair
    Nov 28, 2006 | Samsung MS840 800 Watts Microwave Oven
    How to change control panel for microwave
    I dont see that model in my list but that dosent it dosent exist.. first thing to do is unplug the unit!! Now dont be touching anything inside cause theres a capacitor inside that holds a nice charge.. Take off the cover and look at how the from assy comes out. There sholf be some screws holding the entire front panel in plase. If you think you've located them. slightly pull out on the panel and unplug the plugs and any single wires make sure you mark where they go. Get the board or the entire front panel and reverse instructions. Now its never a good idea for an hobbiest/handyman to mess around with a major appliance like a microwave,tv set or stove. if I were you I would contact http;//www.repairclinic.com and get there # and speak to them directly about this model Or best thing would be to take it into a repair shop to have repaired.. The only problem with replaceing the control panel is the cost ofd the part!! I found that even larger types of good microwaves are less the 200 bucks as some control panels can cost over 125 bucks. it your chice man. Good Luck
    May 21, 2006 | GE JVM1630 Microwave Oven
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
