Question about Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse 27" plasma
Love the TV. We use it in our our home office. The question is this. I understand both the cable (basic) and the PC can be viewed simultaneously. I have misplaced the manual so I am hoping someone can assist. I currently have the cable RG-58 for the TV and a standard monitor cable (9 pin) I think? What are the settings in the TV itself? Thanks Gary
Having same problem as you. need help.
Posted on Mar 13, 2008
Check out westinghouse home page. You can view the manual there.
Posted on Aug 22, 2007
SOURCE:
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download.
www.manualslib.com > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
CABLETV MALE CONNECTOR IS LOOSE ,CAN I REPLACE IT & WHERE CAN I LOCATE IT ANY IDEAS ? WIFE WANT THROWN OUT I LOVE THIS TV WE HAVE PLASMA TVS BUT LOVE THIS TV HELP"
set should have 2 cable connecters; IF IT DOES NOT CONNECT VIA CABLE BOX/SAT BOX ETC TO ONE OF THE SETS OF AUDIO/VIDEO JACKS ON BACK OF SET AND USE IT THAT WAY----the AV jacks bypass the cable fitting.
Tuner could be removed and coax fitting replaced but just go around the problem.
If you do not understand, comment here and I will explain.
SD TECH
Jun 02, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Installed new 27-D01567 power supply unit in my 19" monitor L1975nw. have green light but black screen. whats next?
Is the board brand new or used? You will need to verify the voltage (12~18vdc) feeding the inverter circuits, there is also a surface mounted fuse.
Try reading here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/#step1
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | Westinghouse LCM-19v5 Monitor
Tv doesnt come on
You may have power supply module problem or short circuits in the inverter board, those are the two areas you need to check.
Right now the 5vdc standby is working but nothing else.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Westinghouse+LTV-27W2+&limit=100
Jul 29, 2010 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Parts: www.shopjimmy.com
Jun 25, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse lcd tv parts
can I have your LCD SCREEN? Mine is cracked and I sure could use a new one, or used if thats the case =)
Aug 20, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Connections
You will be able to connect your vcr as long the tv you are buying has a built in tunner tehn you will connect it through the coax cable ant-a or ant b everthing else will connect via rca / hdmi / rgb / S-video good luck
Nov 07, 2006 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
135 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
