Question about Toshiba SD-2800 DVD Player
Reset button back factory - Toshiba SD-2800 DVD Player
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
Mar 21, 2018 | Roku Televison & Video
Can't get tablet to factory reset
Well done so far.
Probably, the button or key you are using to action your command for factory reset isn't correct/appropriate.
Try a few other options.
Please note that
Up/down movement-------a button/key does this
Yes/select----------another key/button does this
Give the entire process another go at factory reset please. It should work.
Best of luck.
Post a feedback asap, please
Oct 11, 2017 | Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
Forgot passcode
Hi friend,
  • You can do the Factory reset
  • 1.Switch Off your device
  • 2.Hold down the Back button and the power button for 10-20 seconds
  • 3.Now go to "Wipe Data/Factory Reset" using the volume buttons and select it using back button
  • 4.Confirm the Factory Reset option
  • Thats it!!!All your datas are erased
Apr 15, 2014 | Coby kyros Tablets & eReaders
How to set the factory default on the router
To bring the router back to its factory default what you can do here is to reset it using the reset button on the router itself.
To do that using a pen or paper clip press and hold the small reset button on the router for 10 seconds while power is ON and then after that let it go and power off and power on the router and its back now to its factory settings.
May 11, 2011 | Linksys WRT120N Router
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
Performing a factory reset via settings
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 | Cell Phones
My HTC tatto phone has become very erratic. After every 1 second of making a call the power end menu options come up on the screen. The phone wont hang up after having pressed the "End Call" button. If I...
First, try a factory reset and see if that resolves your problem. I'm afraid that will wipe all the data on the phone, but you will have to do that anyway if you want to solve this problem.
Here are the instructions for the factory reset:
The most convenient way to do a factory reset is via the phone settings.
  1. Press HOME > MENU, and then tap Settings > SD card & phone storage > Factory data reset.
  2. On the Factory data reset screen, tap Reset phone, and then tap Erase everything. Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the phone buttons.
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button.
  2. Press the ENTER button to begin the reset process. (Otherwise, press the END CALL/POWER button to cancel.)
Aug 06, 2010 | HTC Tattoo Cell Phone
I have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
Jul 29, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How do I reset my password?
there should be a reset button in the back of the router, hold reset button down and plug power in holding for 5 seconds and let go reset button - this will reset password and router to factory default
Sep 30, 2009 | Belkin (F5D7230-4) Router (587009)
Hard Reset
To do a Hard Factory Reset:
Simultaneously press the Suspend/Resume (END) button whilst pressing the stylus tip into the reset opening.
end_button.jpg reset_button.jpg Keep them held until the screen comes back on. Then release the buttons
You will get the Boot options:
  • CLEAN REGISTRY - This resets the device to factory settings, losing applications but keeps the data intact.
  • FACTORY DEFAULTS - This completely wipes everything and resets the device back to it's factory defaults.
  • SKIP
    Try Clean Registry first.
  • Jan 13, 2008 | Fujitsu Siemens Pocket LOOX T830...
    Toshiba SD-2800 DVD Player Logo
    27 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
