Russound st2 smart tuner power issues
Tuner does not have power anymore.
All of sudden my Samsung smart tv only gets one channel!!! Could it be an EASY cable issue?
If your other tv sets work fine, the the issue is with the tuner of your "smart" tv which is currently not so smart!
Nov 06, 2015 | Samsung Televison & Video
"russound x75" + "no power"
Check the power cord with a multimeter for continuity of the wire.Check the fuse unit of the device ,and the soldering points for dry soldering
Aug 31, 2014 | Russound X75 Amplifier
Russound smart media server
What is the problem you faces with this device? Provide more details, please.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 07, 2014 | Russound Sms-3 Smart Media Server 250gb
Russound CA6.4 amp / controller - 3 of the 6 zones can't switch source inputs.
I suspect the inputs will all go into an IC. You just need to trace one of them back till you come across it. Either the circuit around it will be the problem, or more likely the IC itself.
Jul 01, 2014 | Russound CA64IL Amplifier
Russound x75 stopped working wont power on
Check the fuse! Is it plugged in? Is it turned on. Have you read the manual?
Jun 27, 2014 | Russound X75 Amplifier
Replace the TCH-1
I am having the same issue. Did you receive any more information since January?
Jan 22, 2014 | Russound Rnet Touchpoint White -
I have a russound tch1 and since the ios 7 upgrade its not working.
Just saw this on fixya - if you still have the system I would recommend going to Russound.com Support under integration to download the updated firmware for the TCH1 or look into the new perkins innovation unit that supports the new My Russound App
Oct 19, 2013 | Russound Computers & Internet
My unit started smoking and then there was a loud pop.
THAT is a fatal break.
You'll need to call russound and find someone to fix it . Find out HOW MUCH 1st.
Sounds like a power supply capacitor heated and failed ( They smoke and pop)
Apr 04, 2011 | Russound CAA66 2Channel Amplifier
I have the starmate st2 and it does not turn on anymore. I changed the fuse in the power cord. still will not power up. I am considering dropping my service. Help!!
What I did, which was a solution I found on FixYa, is to remove the screws from the back of the unit, pop it open, and resolder the 4 connections attached to the power socket.
Jul 15, 2010 | Sirius Starmate ST2 Satellite Radio...
"cannot connect video smart tee to vmr filter" and "cannot render video capture pin to null filter"
You may be right - the drivers may be gone. Un-install the drivers for it using the Device Manager, and re-install from the CD.
May 23, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
128 people viewed this question
 Grubhead
Grubhead
